Skrypt
An Off-the-grid messaging system.
Public Chat
A wearable ESP32 based hardware that can connected to a smartphone/PC and allows it to communicate with other device with similar hardware. Communication between the hardware and Smartphone/PC is via BLE. Sub-stations/Routers Could be introduced if needed.
The Skrypt is a small piece of hardware that enables communication between devices connected to similar hardware. The Skrypt is ESP32 based and has a small form factor. This allows for it to be hung around the neck or wrist. It simply connects to the device (PC / Smartphone) through BLE and serves as a portal for sending and receiving messages. Long range simplex communication is achieved with the LoRa RFM95W.
The smartphone or the PC only need to have an application installed. All messaging, encryption, decryption and receiving is done on the device. It is battery powered. The Skrypt  could help communication in places where network reception is poor. Underdeveloped communities could benefit from its service.
I will update this as the project progresses.
LoRaSleeve_PCB.rar
The complete LoRaSleeve design files.
RAR Archive - 260.36 kB - 03/18/2019 at 11:44
Download
  • 1 × ESP32-PICO-D4 Microcontroller
  • 1 × HopeRF RFM96W
  • 1 × Battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 1 × AP2112 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × MCP73831 Power Management ICs / Power Supply Support
View all 6 components
  • Change of project name.
    Taiwo07/16/2019 at 19:09 0 comments
    I received an email today stating that the project  name "LoraSleeve"  needs to be changed as it contains LoRa which is a registered trademark of Semtech. This and some other things were the contents of the email. I had to change the project name to something not "LoRa" to avoid the project from being removed from the website.
    So, here we are. Skrypt is the term that came to my mind immediately. Why ? I don't know myself. If another name pops up, I'll update appropriately. If you have a suggestion for a name, do well to  comment and we'll review it together.
    I have been a little busy these few weeks and I'll be back updating the project as it progresses. I have done some hardware tests with modules attached together and we seem to be on the right path.
    There might be a need for an android application as I have been using BLE terminal apps and UART over USB OTG for my tests.
  • With Love from China.
    Taiwo05/24/2019 at 05:23 0 comments
    It took quite a while for the PCB to arrive from China. Who knew China is that far away from here. The overall build quality of the PCB seems okay but I noticed a little problem. The board was a little bit bigger than what I  had in my head  and  I added too much features for such low-power hardware.
    It was probably due to the fact that it is my 4th board (noob alert) and I am still struggling to get my dimensions well. Also because I was a little too ambitious. At the end, I decided to
    • Reduce the number of buttons drastically and allow tweaking of parameters via Wifi/BLE.
    • Use ESP32 Wroom 32 for the next revision as they seem small enough for what I  intend and I have(finally) experience soldering and troubleshooting them.
    • Include a LNA and SMA antenna on the board without compromising its size. Probably a removable antenna or something similar.
    • Make a repeater with better specs and to reduce the transmission time and power required by LoraSleeve.
    • Find a way, if I can, to implement my own RFM96W on board. This does not seem very likely but who knows.
    One important reason for switching to ESP32 Wroom 32 is its availability on Aliexpress compared to Esp32 Pico D4. And Aliexpress (3 weeks) seems to ship faster to my place than Lcsc (still waiting).
    I am definitely not wasting 40 pieces of PCB (39 is okay). I will definitely populate at least one in the coming week ( when LCSC finally comes through)  and will get started on the software.
    I will make a log about the new schematic and layout soonest.
  • Ordering and Panelizing PCB
    Taiwo04/02/2019 at 06:26 1 comment
    I have known about JLCPCB for a while and thought of giving them a try for this project. The PCB is a small one and to save money I thought of panelizing the PCB. I'll have more PCBs for the same price. YAY. There was only one problem, I had no idea how to go about it. I went off to google and searched. I got a couple of cool options. Some easy and others not so easy.
    After deliberating with google and very helpful guys on the HackChat, I settled for GerberTools (https://github.com/ThisIsNotRocketScience/GerberTools/releases). This awesome application has a cool GUI and quite efficient gerber Panelizer. I took me a while to  get the hang of it for I had dimensioned my board on the copper layer (yeah, who does that?). I finally got it to work by removing the dimension and using DirtyPCB's cam files on eagle after it turned out that the app was no fan of the .gbr format. Below is the result I got after panelizing
    Notice the absence of traces in the bottom layer. Thats a bug I hope the maker of the gerber viewer fixes. I displayed it quite well on JLCPCBs gerber viewer though. Well, I am sure the PCB is very well on its way down and will be available in a few weeks.
    NB. I'll update the PCB file again (Sorry)
  • Finishing Up and Cleaning Up
    Taiwo03/18/2019 at 11:37 0 comments
    CORRECTION AND CHANGES TO SCHEMATIC.
    It took a while for me to notice a "little" error in the previously posted schematic. I missed a pull up resistor for the buttons and misspelled some net names . Fortunately, I noticed it before starting the layout of the PCB. In my bid to correct the mistake, I thought it wise to review the components used with the device and made the following changes.
    • I removed the OLED in a bid to reduce the power consumed and since all that it display could be inferred by other means (via LED and the PC/smartphone itself).
    • I reduced the number of buttons to two.
    • I added another LED for power and connection indication.
    PCB LAYOUT.
    I began laying out the components on the board with the aim of making the  PCB as small as possible. There was a limit to its size as I used 0805 components for easy hand soldering ( I can't cope with smaller components ,YET ). I used the ESP32 Pico D4 chip for smaller size. The PCB measured 5 cm by 3.6 cm at the end.
    The new schematic and layout has been uploaded in the project page. Off to JLCPCB...
  • Let's Begin
    Taiwo03/14/2019 at 16:50 0 comments
    SO FAR...
    When I created this project page, I had no LoRa module at hand . I still don't, but I had to get started. I checked my stash of unused components, and found a pair of NRF24L01.
    An RF transceiver, that is not LoRa.
     I played around with its transmission and reception of  messages. I used Serial via the Android Arduino application serial console on both phones. It worked, not well enough, but enough to prove a point.
    My Android development skill is close to non-existent, and I hope to use Thunkable to make an app that interfaces with the ESP32 Bluetooth and sends and receive message from the hardware.
    PCB DESIGN
    I began making the schematic diagram early this morning. The device was to have
    • A small screen to display basic information like battery level, number of connections  etc.
    • A rechargeable battery
    I  used 0805 components and the ESP32 Pico D4. The PCB layout is not complete and I thought I'd share the PDF of the schematic.
    This is the progress so far.
View all 5 project logs
Andrey Ovcharov wrote 07/25/2019 at 08:45 point
I would like to ask about AP2122 chip. Datasheet says it has 150mA output current. Is enough for ESP32? No brownouts or sudden reboots?
Taiwo wrote 07/25/2019 at 12:53 point
I believe the part number in the components list should be AP2112. I have used the chip (AP2122) for some other boards. I did get brownouts. Lots of them. But I switched to a more powerful AP2112. I'll correct the schematic duly and will probably use an AMS1117 for the next revision of boards.
morgan wrote 07/25/2019 at 21:12 point
The AP2112k is a nice linear reg. I'm using it for a couple ESP32 boards, the -3.3 version can supply 600mA and has far better Voltage Dropout than the 1117 (~250mA vs 1.1V). I've also heard the 1117s have very bad current change response times, which might explain why my #ESProgrammer still has brownouts despite being able to supply 1A.
morgan wrote 07/25/2019 at 21:16 point
Oh also, the AP2112 has an EN pin, meaning you can *entirely* cut power to the ESP32 and any other devices on the 3.3V bus, rather than using the ESP32 EN pin.
Taiwo wrote 07/26/2019 at 07:42 point
@morgan  , The EN pin will make a pretty cool way of making the ESP32 switch off itself. Don't you think?
morgan wrote 07/26/2019 at 07:44 point
Yeah, @de∫hipu suggested it to me and I've started using it in all my designs. Works well.
Taiwo wrote 07/26/2019 at 07:49 point
How interesting would it have been if the AP2112k could supply 1A of current. Or is there a hack somewhere? @morgan
x893 wrote 07/16/2019 at 16:26 point
Awesome project ! Can you explain situation with firmware and software for windows/android ?
Thanks
Taiwo wrote 07/16/2019 at 18:47 point
Thanks. I am yet to begin the android app implementation. For now, I use either a BLE terminal (android and windows ) and Uart over USB OTG on android. I have no skill related to android development and would love if someone could help in that regard. I am still trying to solve minor quirks with the hardware.
Thanks
wb8wka wrote 07/17/2019 at 01:56 point
Is the firmware source available and do you have the protocol documentation available?
x893 wrote 07/17/2019 at 09:07 point
Hello,
Not understand about firmware for ESP32. What do you think about nRF52 + SX127X ? Or you need WiFi for communication with device ?
Taiwo wrote 07/17/2019 at 09:18 point
The esp32 firmware is a mess right now but I'm trying to fix it. I've been a little busy these days. nRF52 (and any other mcu with ble and usb) will work very well with the SX127X for the project . My own setup just happens to contain an esp32 because I have them in abundance and they are quite easy for me to program. The firmware does not use wifi for now (at least not Yet).
x893 wrote 07/17/2019 at 09:52 point
I have nRF52 + SX1276 module (RAK813 https://ru.aliexpress.com/item/32844878395.html) and can port ESP32 firmware to this module. Firmware for BLE UART ready from Nordic SDK. So if you publish (or send me directly) i can try to port.
Wo King wrote 07/12/2019 at 08:03 point
I am new to LORA so please be patient. Is there a restriction due to legally how many messages can be sent per hour?
kiu wrote 07/12/2019 at 09:13 point
Yes, there are legal restrictions (ISM Band usage) and depending on which LORAWan network you are connecting to, the provider has its additional rules and costs (when its a commercial network).
TTN is a good start: https://www.thethingsnetwork.org/forum/t/limitations-data-rate-packet-size-30-seconds-uplink-and-10-messages-downlink-per-day-fair-access-policy/1300 and https://www.thethingsnetwork.org/docs/lorawan/duty-cycle.html
don.vukovic wrote 07/12/2019 at 04:45 point
Please reload  LoRaSleeve_PCB.rar, it seems to be corrupt.
Taiwo wrote 07/13/2019 at 23:13 point
Thanks, I will.
yusuf kehinde hussein wrote 03/31/2019 at 08:01 point
This is a cool one.
Taiwo wrote 04/01/2019 at 11:15 point
Thanks
Taiwo wrote 03/07/2019 at 05:26 point
Thanks a lot.
Josh Lloyd wrote 03/06/2019 at 18:24 point
This is a very cool idea. One thing I personally think will be important is end-to-end encryption between devices. Especially if the relays are open source
Taiwo wrote 03/06/2019 at 19:38 point
Yes, that's a good one.  I might have to learn a thing or two to implement that though.
Josh Lloyd wrote 03/06/2019 at 21:22 point
When you eventually get there I'd be more than happy to help.
