• Progress
    jlbrian74 days ago 0 comments
    Progress is slow, but it is coming together.
    The PCB's have arrived, and I will have all of the components to build one up this week, I should have the drawing finished this weekend, including the components that need to be 3D printed, and the files are accessible here: https://sethlans.io/code/jlbrian/tank
    The parts that do not have the academic version watermark were downloaded from https://www.3dcontentcentral.com/
    and the files that have funny names are from converting the .igs for rplidar into a solidworks part.  I wanted to see if it would fit on the frame.  https://www.slamtec.com/en/Lidar/A1
  • Power and Test
    jlbrian703/08/2019 at 01:01 0 comments
    To power the tank I took apart a DeWalt LiIon adapter https://www.ebay.com/p/Dewalt-Dca1820-20volt-Max-Battery-Adapter-for-18volt-Tools/6030009643?iid=273258375426&chn=ps and used the tool foot for the battery, only bringing out the B+ and B- wires, so there is no battery management here.  I took it outside the first time I tested it fully prepared to run away, but every thing went fine mostly.
    I had built the H-Bridges with tip 102's and tip 107's and used two ti DC-DC converters.  Apparently I made an unwanted solder bridge somewhere because one of the motors would only run in one direction, but it was enough for me keep going with it.
    Boards have been made and shipped, so I'll test out the L298P and see what kind of results I get with that.
    I also saw this as a good opportunity to begin to learn solidworks, so if everything goes well I will post all of the drawings, assuming that solidworks licensing agreement is not as restrictive as NI Labview.
    Best i can tell there is no restriction on the files so long as i dont remove the water mark.
