Designing Coils for PCB
A project log for Flexible Metal Detector
Taking inspiration from @BugejaCarl I whipped up a flexible metal detector board based on lpodkalicki 's attiny13 design
ray-olsenRay Olsen 03/08/2019 at 04:560 Comments
I really just wanted to jump into this project, mainly with out thinking/looking
I've seen [Carl]'s projects hear and some of his progress on twitter.  I popped open EagleCAD and went straight for the ULP's.
spiral-coil.ulp
copying the spec's from the original:
I went with 0.5 mm for the width and 30 turns as specified
I used 0.2 spacing as that is the minimum for flexible PCB from OSHpark
Which dumped out this:
I wasn't sure if i was going to be able to line up the vias since Eagle is a baby.  I am going to look into separating this as well as spacing out the center to make a more usable coil for metal detecting.
I streamed myself working on this
Watch Flex PCB Design Contest from tankstein on www.twitch.tv
