• Progress
    Hamlin03/08/2019 at 20:43 0 comments
    |-------------------------------------------- Initial (08 Mar 19) ---------------------------------------------|
    - Modeled battery tray and source (pwr) system
    - Modeled mounting surfaces for components
    - Determined dimensions of chassis (PLA Spacers/All-Thread)
    - Modeled/printed solar panel arrays
    |-------------------------------------------------- 12 Mar 19 --------------------------------------------------|
    - Modified solar panel array to compensate for shorter chassis and increase accessibility to micro controller(s)
    - Heavily modified and printed source system
       >> Programmed individually addressable LEDs to simulate booster engine
       >> Printed ignition tube, wired LEDs, mounted system inside source
       >> Modified rotating assembly w/guide; mounted system and tested
    - Began assembling chassis; source functional/capable of rotation
    Note: Multiple issues with corner warping on prints. Issues began after replacing extruder fan which is directly wired to a source; rewired to sequence with a regulated fan and decreased rpms.
    |-------------------------------------------------- 15 Mar 19 --------------------------------------------------|- - Modeled and printed surfaces for 9-axis gyroscope
    - Mounted GPS, shortened external antenna coaxial cable
    - Modified booster simulation sketch
    - Modified/printed Uno mounting surface to permit access to Nano
    - Researched how to interchangeably communicate with GPS via serial and BLE via AltSoftSerial
