The Intelitek Prolight CNC Mill was a fabulous machine. If you are looking for a CNC retrofit project, this is the machine to use.
ProLightWiring.xlsxProvided by Chris Itterly from the Kalamazoo makerspace.sheet - 15.43 kB - 05/06/2020 at 13:37 |
Apologies for not posting anything after the initial project page was put up. A lot has happened since then.
That machine weighs a little less than 500 lbs so I had to build a frame for it to sit on.
The spindle speed is still set via the original manual controls, but that isn't that big of a deal. Adding an encoder on the spindle should help resolve that manual step.
I posted the components I was planning to use in the description. Here you can see that I took an old electrical enclosure and re-purposed it. I unfortunately did not plan it out very well. A lot of the cables would have been at strange right angles within the enclosure. At the last minute a friend with a laser cutter helped me mount the G540 on a piece of Acrylic.
What is not seen in the photo is where heat sinks were applied to the back of the G540. When I get back to it I will need to include a CPU fan, move the E-stop to the top, build doors (probably also arcylic now), and mount it to the side.
Remember that table size? Yeah, you can mount a 4'' Kurt vise at a 90 if you would like, but you lose a lot of Z in the process. | wanted something a little smaller, and little less heavy. So I got on the ol'Amazon and got a crummy Chinese vise delivered.
Unfortunately, the dang thing must have been ground in with a belt sander. I think I found it 0.013 off, and a nice concave shape on the bottom. You get what you pay for, but nothing a little grinding won't fix.
The moment of truth. I was planning on running Titan's of CNC tutorial on it, but decided I should just do a simple test cut.
Huzzah! It works.
There are some parameters that one needs to be aware of when using the AcornCNC software, in particular there are different profiles. These profiles set for example the line segment lengths used in circular moves. If you look closely you will see there is a good .125 line segment on that island. Turns out I was running it in the roughing profile. Not bad though for a first test.
I also purchased the Wireless Electronic MPG Pendant, which makes running this thing soooo much easier.
Well, I have an encoder waiting to be mounted on the machine. I believe there is a 2:1 belt setup between the spindle and motor and I am investigating how I can place the encoder on the motor fan mount. If I can get that running then rigid tapping becomes available as will electronic spindle speed control. Then I imagine it will be time to put an enclosure around that thing. I spent just as much time sweeping as I did cutting.
I would like to find a used but working Pocket NC. I know the prices very well, but they are really exorbitant, and unfortunately I don't know anyone with this interest with whom I can share the expense. The machining I am interested in is: milling pistons, connecting rods, crankcases, etc. In short, everything related to modeling. In particular, I would like to start production, even in a small way, of a fantastic seven-cylinder rotary engine. Please let me know. Thank you very much!!! 🙂
hi Guys it looks like this project has ended but If anyone is looking for one of these little machines I have one available. I’ve updated the control on mine to mach3 already.
Not a comment, a request .. a favour. I have a Prolight 1000 as well and I now have to move it, a long distance. That means building a crate and bolting it down to the crate. Only I don't know the bolt pattern and can't easily measure it, as mine didn't come with mounting feet.
Even getting it on the pallet is going to be tricky.
Could I ask you to measure up your mounting feet location? Thanks.
Why publish project details if you are not going to engage when asked a question
Because this is what I do for fun when I am not trying to raise my new 4 month old daughter.
I fully agree. This way of doing things is really unnerving, and it does not only affect this link, but is found everywhere. I am also interested in the implementation of the project, but by doing this we only have an idea and, in the end, nothing concrete. Every time you have to start from scratch with your own ideas.
Drew, thanks for sharing. Can you share more details on how you got the machine to work with the AcornCNC controller board and a Gecko G540.
more details will be appreciated. I am willing to do drawings and documentation if it would help. How to connect the board to the G540 and the software setting.....
I recently purchase 3 intellitek machines from an auction, withoutthe controllers. 2 mills and a lathe. I would like to find a solution to cnc controls for these machine again.
I learned on these at my high school 20+ years ago! I now have a Taig with about the same travel but not nearly as much weight. Saunders has a good tooling plate and modular vise that would fit well:
https://saundersmachineworks.com/collections/all/products/taig-aluminum-fixture-tooling-plate
https://saundersmachineworks.com/products/modular-vise-system-1-4
Yeah...I actually bought the SMW fixture plate and vise. I bought the steel one though for the grizzly, which I don't see on the site anymore. The concept I had was that while its area is larger than the machine's build volume, I could place fixtures just outside it. That way I am not losing any x or y travel to fixturing.
This was probably a "pre-optimization" error though. I totally ignored looking at the AL plates he had and now that I see the Taig plate It looks like it would mount with little modification. Shucks...
https://saundersmachineworks.com/products/grizzly-g0704-fixture-tooling-plate
I have a one of these and Lathe bought for my class at government auction unfortunately they crushed the computer with the card. Let’s get this going
I've found the AcornCNC to be pretty easy to work with. Does both lathe and Mill.
My first child is what happened. I am actually much further along than the initial post. The machine is operational, and I have an encoder that needs to be mounted on the spindle so I can support rigid tapping.
Are these machines no longer made? That would be a shame, they seems like a great entry level machine. Looking forward to details on your mods.
The prolight's as a line I believe are discontinued. Intelitek though still has mills based off the castings still. At the price they are asking for though I would just as soon as get a tormach.
When converting a Prolight 1000, he devil is in the details. Readers may find this helpful:
https://www.youtube.com/watch?v=dlSlQNzwuOA
