Analog signal processing
A project log for Universal Touchscreen
Let's turn every surface into a Touchscreen on the cheap !
cmcCmC 08/19/2014 at 07:190 Comments
The signal comming from a piezo is really uneven. First of all in order to be able to compare the signals, they need to have some similarities. I
found that the signal is almost a sinewave (with decreasing amplitude). Here is a screenshot of my (little) oscilloscope :
My idea was to rectify the signal so that I only have to care about amplitude.
I used a rectifying bridge (Gretz Bridge) in order to do that.
What a noisy signal !
After passing it through an amplifier and an RS latch :
Now we are talking !
