Designed to be easy to use, only one button, an encoder serves as navigation and selection button, easy on/off, upsidedown sensor to turn it off, with memory at all functions, autorestore in chase of temporaly interruption of electricity.
Functions:
- Adjustable power
- 5 Wachfaces
- Timer (Summer&Winter)
- Time, timer & power memory
- Upsidedown sensor
- Diffuse light output
Specs:
- OLED Screen 1"
- 4x5W Cold White COB LED
- Power: 20W
- Input: 220V
- Aluminum case
Eduardo
This screen was designed to see the power output at large distances of the display.
This screen was designed in order to be precise but graphical too.
This screen shows the time, and the bar shows the power wit less priority.
This screen shows the timer menu screen and time configuration, was designed to show all the info in once screen and to configure the device.
Robert Poser
JamieK
James Rogers
