Corner Nigth Light
Simple light with effects.
Corner ligth with addresable leds and a temperature sensor that can be controled trouthg a capacitative sensor.
This proyect was intended to be a corner lamp, in order to optimize the space, not everybody lives in a californian mansion... it was designed with a few things in mind, for example, a shape without corners, some people can use this for his bed.
Its was thinked to have a termometer mode, blue colors from the botom to red colors to the top, switching some leds from temperatures at 15ºC to 35ºC (the most usual temperature range in a home).
Also its thinked that have a love mode, with dancing pink, red and purple colors, you know ;-D
Fire mode its another must have...
It doesnt have buttons or anything, only touch the metal to switch modes, long touch turn it on or off, short touches change modes.
Programable via USB to change the modes and patterns, also the only way to supply energy its the USB port to, no big, chunky and old barrel jacks.
Its intended to make a bigger and better version, this only measure 12cm of height, the new version must measure almost 20cm and got an IR sensor on each glass/methacrylate panel in order to have tactile detection, all this inputs gonna be to set the mode and light intensity, it also gonna have a capacitative sensor on the body to turn it on or off.
Some variations are made, more aestethic, but with shape corners or even not sperical shape, maybe I made a 180º variation for walls aside from the corner version, I want to see the acceptance of the public.
This proyect its shelved because I dont have money to make it real, and now im more interested in work for the higer version.
  • 1 × Outer Shell Made - Workshop
  • 9 × Metacrylate diffusers Made - Laser Cut
  • 1 × 4.7μF Capacitator Buy - Electronic Components
  • 1 × ?μF Capacitator Buy - Electronic Components
  • 2 × 3.6V Zener Diode Buy - Electronic Components
View all 15 components
  • Variations
    Eduardo04/09/2019 at 12:09 0 comments
    Angular:
    Chinese sky lantern:
    Box:
    Cilinder:
  • Details
    Eduardo04/09/2019 at 11:32 0 comments
    As someone ask in the comments, here are more renders about some details.
    USB Plug:
    The only one view angle from where you can see the led´s:
    PCB:
    Slice to understand how are all placed inside
    Render with transparency:
View all 2 project logs
  • 1
    Step 1
  • 2
    Step 2
  • 3
    Step 3
View all 10 instructions
beamrx5 wrote 03/21/2019 at 16:41 point
best if LEDs are hidden in plain sight.
Eduardo wrote 03/21/2019 at 17:59 point
Are hidden inside the body, maybe uploading more renders I can clear it to you.
Richard Hogben wrote 03/21/2019 at 16:01 point
What do you use for your illustrations?
Eduardo wrote 03/21/2019 at 16:30 point
what tha... thas was uploaded a moment ago... o.o
Sketchup & Autocad
I use deep render options, you need some time to learn how to make them.
Richard Hogben wrote 03/21/2019 at 16:33 point
Cool, the light reminds me of some of the organic shapes from #I LOVE LAMP
