Assembly
06/20/2019 at 13:15 • 0 comments -
Software
04/27/2019 at 21:41 • 0 commentsBrief revision of the serial console.
Serial commands:
help:
__________________________________________________ | - RGBW v4.0 - | |________________________________________________| |Commands: | | onoff allon alloff | | data cycle resetsettings | | help savecolor[1-8] callcolor[1-8] | | wt levelw[0-100] lramp[0-10000] | | rt levelr[0-100] lcramp[0-10000] | | gt levelg[0-100] lstay[0-30000] | | bt levelb[0-100] ldimm[0-99] | | | |Tuners: | | r+ g+ b+ w+ | | r- g- b- w- | | stay+ ramp+ cramp+ rgb+ | | stay- ramp- cramp- rgb- | | | |Colors: | | red ltgreen green magenta cyan white | | blue ltblue orange rgbwhite gold violet | |________________________________________________|
Provides this help frame with all the commands.
onoff:
Turn off fast and turn on to the last color.
allon:
All colors on to the highest level.
alloff:
All colors off.
data:
__________________________________________________ | Data: | | White | Red | Green | Blue | | 0 | 255 | 0 | 255 | | 0% | 100% | 0% | 100% | | - - - - - - - - - - - - - - - - - - - - - - | | Ramp | Cycle Ramp | Cycle Stay | | 300 | 1500 | 2000 | |________________________________________________|
Show this data frame.
cycle:
Start/Stop the cycle mode. It change the color from the 8 memory colors. It gives this frame:
__________________________________________________ | Cycle Mode | | On | |________________________________________________|
resetsettings:
This reset all settings to the factory settings.
savecolor:
Save the current color to the desired position:
savecolor 4
callcolor:
Call the selected color:
callcolor 4
wt, rt, gt, bt:
Color toggle, it switch the selected channel.
levelw, levelr, levelg, levelb:
Level input, use to set a desired level in %:
levelw 74
It gives the next frame:
__________________________________________________ | White Level:74% | |________________________________________________|
Can be seted from 0 to 100.
lramp:
Level ramp, use to set a desired time in ms:
lramp 300
It gives the data frame updated. Can be seted from 0 to 10000.
lcramp:
Level cycle ramp, use to set a desired time in ms:
lcramp 300
It gives the data frame updated. Can be setted from 0 to 10000.
lstay:
Level cycle stay, use to set a desired time in ms:
lstay 300
It gives the data frame updated. Can be setted from 0 to 30000.
ldimm:
Level dimmer, use to set a desired level in %, it gives the data frame updated. On cycle mode it gives this data frame:
__________________________________________________ | Data: | | White | Red | Green | Blue | | 0 | 200 | 0 | 200 | | 0% | 78% | 0% | 78% | | - - - - - - - - - - - - - - - - - - - - - - | | Ramp | Cycle Ramp | Cycle Stay | | 300 | 1500 | 2000 | | - - - - - - - - - - - - - - - - - - - - - - | | Cycle On | | Dimm:50% | |________________________________________________|
w+/- r+/- g+/- b+/-:
Increment/decrement the selected color
stay+/-:
Increment/decrement cycle stay time.
ramp+/-:
Increment/decrement ramp time.
cramp+/-:
Increment/decrement cycle ramp time.
rgb+/-:
Increment/decrement all colors.
red:
Set red color (r100%)
blue:
Set blue color (b100%)
green:
Set green color (g100%)
cyan:
Set cyan color (g100% b100%)
magenta:
Set magenta color (r100% b100%)
gold:
Set yellow color (g100% g100%)
orange:
Set orange color (g100% g14%)
violet:
Set violet color (r65% b100%)
ltgreen:
Set ltgreen color (g100% b9%)
ltblue:
Set ltblue color (g74% b100%)
white:
Set white color (w100%)
rgbwhite:
Set rgb white color (r100% g100% b100%)
Buttons:
Buttons have two push modes, short and long press: Button 1 on short press use the
onoff
command
, showing the next frame__________________________________________________ | On | |________________________________________________|
On long press use the
wt
command
, showing the next frame__________________________________________________ | White toggle | | On | |________________________________________________|
Button 2 on short press change through the seven color mode, showing the next frame:
__________________________________________________ | Mode:1 | |________________________________________________|
cycle
command
, showing the next frame__________________________________________________ | Cycle Mode | | On | |________________________________________________|
IR Remote
When a signal is received this frame appears:
__________________________________________________ | IR Signal Recieved | |________________________________________________|
The IR functions are limited to the following commands:
w+/- / r+/- / g+/- / b+/-
wt / rt / gt / bt
alloff
allon
rgb+/-
cycle
cramp+/-
stay+/-
ramp+/-
onoff
red
green
blue
cyan
gold
magenta
violet
ltgreen
ltblue
orange
rgbwhite
New design
04/27/2019 at 21:18 • 0 commentsv2.0
v1.0
