PCB received​
A project log for 2D stepper motor etched on PCB - micro manipulator
It is compatible with standard stepper motor diver, cnc or GRBL shield, direct replacement of X-Y stepper motors.
bobriciusbobricius 06/04/2019 at 20:411 Comment
PCB received
Matt Foreman wrote 07/26/2019 at 22:08 point
First off - Amazingly cool concept!
I ordered a few of these boards and haven't found a definitive wire guide. I attempted to drive one axis using a DRV8825 IC but could not get the magnet to move.
I don't know if it is because:
1. I wired it wrong
2. I am using the wrong type of magnet (~5mm and unknown composition)
I am concerned the DRV8825 might not be a good fit as a driver, its minimum voltage is 8.5V. It didn't seem to make the PCB hot (although it did warm up!).
Thanks for sharing such a fun concept to play with!
