FLEXIBLE 2.5D actuator, stepper motor compatible
It is compatible with standard stepper motor diver, cnc or GRBL shield, direct replacement of X-Y stepper motors.
With flexible boards you can partial move in Z axe :) if you warp board.
Magnet is moved only in horizontal X-Y space. It can push small object, I have no way
now how to pick and place object or I have no communication and feedback from robot.
Feedback is possible with camera or hall sensors under board, also there is way
to communicate with bot over NFC/RFID with coil under board... untested now
you can move only one magnet, more magnets move paralel, but you can
divide moving space to zones and use more robots ... etc parking zones if you have more
magneboots with different tools
My latest design use 0.6mm board but this is very fat,
bottom trackers are weak compared to top trackers
I have plan make only tracking part from flex and controller as normal 1.6mm board
Thanks PCBway for support with board manufacturing! https://www.pcbway.com/
Last version is compatible with standard stepper motor diver, cnc or GRBL shield, direct replacement of X-Y stepper motors.
Latest Speed and repeatibility in one dimension is very good.
One dimension simplified version is here: ant-highway-precise-linear-circular-motor
Check My 2D version with another coil configuration
https://hackaday.io/project/154496-2d-actuator-move-micro-robot-in-xy-2d-space
  • 1 × PCB Magic PCB
  • 4 × 2mm N52 magnet
  • 1 × stepper motor driver CNC shield, GRBL or ramps board
  • 1 × NOTHING more !!!!!
View project log
ekaggrat singh kalsi wrote 3 days ago point
y is this called a 2.5 d? really cool work .. If you could control 2 robots simultaneously it would make a cool clock. i hae always wanted a minimilistic clock with just 2 circles moving about on a surface !
bobricius wrote 3 days ago point
if you wave flex board you can can move in Z position of course this more joke than practical. you can not control 2 elements now, but you can separate board to more zones. I have no purpose now for this because I have not solved something like "hand" it can just push objects :( if it can carry smt component ... it can be amazing pick and place, but I have no idea how to do.
saipraveen wrote 04/11/2019 at 09:21 point
Well implemented. Neat ! Any plans of making it open source ?
bobricius wrote 04/11/2019 at 10:52 point
Yes, if I win TOP20 in Hackaday prize 2019 :)
deshipu wrote 3 days ago point
Don't the rules of the prize require you to open source it?
Of course, I will publish all the documents, but now I have to keep people doubt. ... In end of May. I have not tested latest design.
Daren Schwenke wrote 04/08/2019 at 21:11 point
You had me at Lego. #P1 - Lego compatible drag feeder The project is pretty neat too.  :)
Hamish wrote 03/24/2019 at 19:43 point
Did you notice heating issues in this design when you run it for a longer period of time? What about actuating more than one magnet independently?
Alexander wrote 03/23/2019 at 00:11 point
I love 2D magnetic robots! Hope to see more details posted (:
