Bumps.
03/23/2019 at 15:39 • 0 commentsThe two bumps (spheres in the code) which are the latch and snap it closed could use to be slightly taller.
That's a bending interface and the force applied crosses layer lines, so a delicate balance must be struck.
<EDIT>
Fixed. New source and rendered files are up.
</EDIT>
Hinge issue.
03/22/2019 at 21:56 • 0 commentsI didn't make the hinge area thick enough and it didn't hold together after printing.
Fixing it.
<EDIT>
Hinge is fixed. Also sorted the outer wall bug and made some other tweaks.
Updated the files. Reprinting.
This is actually a pretty small box, so the hinge isn't nearly as large as it looks.
</EDIT>
Two bugs.
03/22/2019 at 19:43 • 0 comments- The outer wall has to be set to subtract 1/4 of the inner wall value, to be the right value. So to get a 0.8mm outer wall, with a 0.8mm inner wall, you have to set it to 0.6mm.
- You need an odd number of 'rows' to have the hinges closed on both ends.
