Orange safelight for field photography
For the initial design it was intended to use a side push button, coupled with a D-flip-flop to turn the power on and off. The idea was that when you are working in the dark, and want to turn the light on or off, you don't have to wonder which way to move a button; you just push, and it toggles.
Sadly, I couldn't come to have the flip-flop work. After checking the board maybe twenty times, after having checked for shorts, after having changed the components around, suppress or add capacitors, resistors, nothing. On some boards it was always on, on other always off. After having look around the Internet, I discovered that this flip-flop needs a fast switching on the clock line. So I even tested it with an Arduino giving the clock edge. Nothing. I've also tried to disconnect the set and reset pins of the IC, that are active low and can be tied to VCC. Here it almost worked. Almost. After a few days I gave up.
So, new prototype, with a side sliding switch instead of the push button + flip-flop. The BOM is smaller, the cost as well, and I've design a new enclosure and slide button that will be easy to use. A batch of boards has been ordered, assembled, and this time everything is ok.
Next step is building the enclosure. 3D printer is now running to print the bare parts that will soon become the master for the mold, and the silicone and PU resin have been delivered yesterday...
Oh, and : someone asked about the color used, and I realized yellow led seems to be outside the collodion sensivity. So I'll give a try to yellow. If the collodion agrees, it should be even more comfortable than orange !
While working on a project, there is always a moment where some question arise, as "am I right with the choices made", or "shouln't it be better to use this kind of switch", and so on.
They usually come an hour or two after having ordering the first batch of prototypes.
This time, there are two things:
- Should the USB port for powering or charging be placed behind ? It implies a longer support bracket. Maybe putting on one side (sorry for left-handed !) was a better idea...
- Is the lipo battery really a good idea ? Using cells would be cheaper (ok, the charge circuit costs virtually nothing), and they offer an advantage : when you battery dies and you can't charge it, you can find cells everywhere...
Feel free to let me know...
This is as new as it could be ! The first drafts have been made this week, the circuit designed, the enclosure as well.
First pcb prototype batch has been ordered yesterday, as well as components.
A physical mock-up has been made to see what it would like when finished.
Now it's time to wait for everything to arrive.
And refining enclosure, support bracket, and preparing molds...
Hi !
To me RGB leds are a wrong way to go : if you use red, you are ok, as red is beyong the top wavelength sensivity of most emulsions. But is you use orange, or yellow, you have red and a relative amount of green. Your eyes sees orange or yellow, but the films sees red + green. And green will fog or expose film. And blue even more, of course. As a side note, I wonder if RGB led could be used in an enlarger to generate red light for focusing, and multigrade light for exposing...
Here I'm going to use orange leds (5050 format), they have a suitable wavelength and a relatively narrow bandwith.
Interesting. Are you going to use RGB LEDs to generate light at the proper wavelength or use white LEDs and a filter?
