Flex PCBs and Components Ordered
A project log for Möbius Flex
My entry for the flex PCB contest. I'm not sure how well a flex PCB will work for an LED-studded möbius strip, but let's find out.
chris-millerChris Miller 03/29/2019 at 22:380 Comments
I've ordered the flex PCBs from OshPark and the components from Digikey.  I should have them within a few weeks.  Next update will likely be assembling one.  I have not ordered an SMD stencil yet.  Since the flex takes a little longer to arrive, I thought I'd spend the next week or two experimenting more with laser cutting or vinyl cutting a stencil from Kapton or mylar.  I've had some success in the past, but these are small parts..
