More Devices
A project log for Finding a way through the jungle of smart home
How much smartness does our home need and what I would like in no case.
xo-ne-unXo Ne Un 04/11/2019 at 17:180 Comments
The support of iobroker is really awesome. Support of Paulmann switch controller 500.43 is integrated and will be available with next version of zigbee adapter 0.10.3.
Meanwhile I've tested a Xiaomi Aqara double switch successfully and a RGB LED controller of Paulmann 500.49 that works also fine only the teaching was a little bit tricky.
Since the last weeks two Osram smart+ plugs run without problems.
