STL files uploaded!
A project log for UV Curing Chamber
A UV light curing chamber made with an old rack, some aluminum foil, and three 50W UV LEDS. An Arduino is used as a programmable timer.
andrs-lopez-pulzovanAndrés Lopez Pulzovan 08/29/2020 at 15:040 Comments
The files to 3D print the case were uploaded to the project page! The 16x2 LCD and the relay board should fit right away. Note there is a square perimeter: the (disassembled) wall wart transformer + the rectifier are fitted there to provide isolation.
