Arduino sketch uploaded!
A project log for UV Curing Chamber
A UV light curing chamber made with an old rack, some aluminum foil, and three 50W UV LEDS. An Arduino is used as a programmable timer.
andrs-lopez-pulzovanAndrés Lopez Pulzovan 08/29/2020 at 15:130 Comments
The Arduino sketch was uploaded to the project page! As mentioned in the project's details, it is heavily based on the Arduino Kitchen Timer project (linked in this project's details) and in the code. The modifications were made to actuate the relay when the timer is started, and turn it off when time runs out (or the timer is manually stopped).
