How large is my Board Going to be?
A project log for Flexible Coffee Cup Buddy
The aim of this project is to design a flexible PCB that can be attached to a coffee cup and will visually represent the temperature.
billy-bogardusBilly-Bogardus 03/31/2019 at 02:230 Comments
I was thinking it would be cool to plaster the whole outside of my coffee cup with RGB LED's (WS2812B).
Then I measured the cup and did the math.
Diameter = 3.24"
Height = 3.83"
Circumference = PI * Diameter = 10.178"
Surface Area = Height * Circumference = 38.98 sq. in.
Flex PCB Cost = $15/(sq. in.) * Surface Area
Board cost = $584.70
 That is quite expensive and I don't even have the components yet!
However, that is three copies of the same board so if i did a 1/3cup design I could combine them to cover the whole coffee cup.
Area = 12.99 sq. in.
Cost = $194.90
That's still expensive for a design I have not proven yet.
How about trying this.
Area = 2 sq. in.
Cost = $30
However I receive 3 boards.
Therefor Total Area = 6 sq. in.
Coverage = Area of PCB/ Surface Area of Cup * 100 = 15.39%
Now I just need to figure out the layout and the routing.
Enjoy a photo of the coffee cup I used for my measurements.
