in my version it is made a dry distillation of wood with a wood burning stove with cast iron rings, in the condensation spiral will produce useful products such as acetic acid, tar, acetone and other, more lean gas that is sent to heat the radiators together to 'hot water coolant. In practice it is a fireplace, which in addition to heat, also supplies charcoal and above products ....
