iOS/Android App
A project log for Plant Environment Monitor
Wireless sensor for monitoring home plants.
alexey-volkovAlexey Volkov 04/25/2020 at 20:145 Comments
A simple application for iOS / Android is ready. Supports multiple sensors.
tBStar wrote 09/02/2021 at 14:48 point
I appreciate it.
About your soil moisture sensor, can you tell me the reasoning behind including the sensor data in the advertising packets?
Fyi, I have similar project where I m using the same nNR52 SoC.
Alexey Volkov wrote 09/02/2021 at 15:05 point
1. Saving energy (You can use the intervals not affordable to maintain connection.)
2. It is convenient to use with a BLE -> MQTT gateway .
3. And much faster than connection - search service - reading characteristics - disconnection.
tBStar wrote 09/06/2021 at 17:28 point
Great insight, thank you very much
tBStar wrote 08/09/2021 at 00:58 point
Alexey,
is it possible to publish the source code for the mobile app?
Thanks
Alexey Volkov wrote 09/02/2021 at 14:33 point
Yes. I will publish source and add a link to the project page.
