DC27 MULTI PASS
Back to overview
DC27 MULTI PASS BADGE. Theme from the movie "The Fifth Element" and a micropython platform.
Papa wrote 08/05/2019 at 07:33 point
Couple of things if you're on a PC using Windows 10:
1) The Serial Port driver for the pyserial will auto-install once you update to the very latest version of Windows 10
2) The connect string in mpfshell is "open COMx" instead of "open ttyUSB0". To figure out what value to put in for x, check the Device Manager under Ports. If you have a yellow exclamation mark next to anything in that folder, see point 1.
3) When/if you go to upgrade the firmware, use the esptool.py.exe under /python 2.7/scripts (in my case, your location may vary depending on what python installer you used). The command line will be something like (assuming you downloaded MultiPassFix1.img into the current directory) :
esptool.py.exe --port /dev/COM3 --baud 921600 write_flash 0x00000 MultiPassFix1.img
The touch buttons on the badge work MUCH better after you install the fix!
mrod42 wrote 08/01/2019 at 14:20 point
from terminal.
cd /dev
ls
This will show your mount points, select and copy the one that says something to the effect of
tty.SLAB_USBtoUART
run mpfshell, and use
open tty.SLAB_USBtoUART
have fun.
anthonymonge wrote 07/27/2019 at 23:29 point
Just got the badge today and I enjoy playing around with it. However, my skills are poor with what I want to do. I am trying to connect to the badge through a serial connection but I cannot get it to work. I have MPFShell up and running, but finding the correct port to tty into is impossible. I am using a MacBook Pro. Any help?
