April 23rd Status
A project log for ESP32 LED & Motor Driver
An ESP32 based controller that can drive any kind of LED strip, or motor. Includes microSD, USB-UART, and large voltage range input.
bill-eckmanBill Eckman 04/23/2019 at 10:110 Comments
The board is assembled.  No major issues.  There are three minor issues that will be fixed in the next revision of the PCB.
I powered the board from a 15V power supply.  No issues with power were found.
I loaded Micropython on the ESP32 over the USB port.  No issues were found.  I successfully setup the ESP to connect to the network over wifi.  I will continue development and testing.
