A Ton of Functions
A project log for Terminal-BASIC programmable calculator
A poket-to-laptop size microcomputer/programmable calculator, based on Arduino DUE and Terminal-BASIC
ptravptrav 06/15/2020 at 10:191 Comment
Over 70 application functions have been implemented so far.
The full list is here.
For instance, if you want to compute an average, it is easier than on HP-35s!
Common Experiment Processing
Given: In the dance class of 10 students, the heights were measured at 147, 152, 165, 163, 168, 163, 175, 166, 170, and 167 cm.
Find: The mean height and its standard deviation in the class.
  1. Type clear sum, <Enter> (a shortcut is <F1>, <A>, which displays clear )
  2. Type sum 147, <Enter>
  3. Type sum 152, <Enter>
  4. Continue for the other 8 numbers. Instead of typing sum, you also can type a number and press <F1>, <S>
  5. After each number the calculator displays number of samples, the mean and standard deviation.
After entering all 10 numbers, the display shows:
N____________________10
StDev________ 8.30261003
Mean______________163.6
Sum updated____________
>_
Answer: the average height of the class student is 164 cm (68% of samples are in the interval of 164±9 cm).
Normal Distribution and Probability
Given: In the dance class as above, assume normal distribution and fair representation of the school population.
Find: (1) Probability the next class participant is taller than 175 cm. (2) Interval of heights for 95% of the school population.
  1. Type prob(175), <Enter>
  2. The calculator displays: 0.91513344. This is the probability the next participant is under 175 cm.
  3. To find the answer, type 1, <Enter>, <Arrow Down>, <->. The calculator displays: 8.48665622e-002.
  4. Type 1, <Enter>, 0.95, <->, 2, /, probit,<Enter>.
  5. The calculator displays: 147.3(...) This is the lower value.
  6. Type probit( 0.975), <Enter>.
  7. The calculator displays: 179.9(...) This is the upper value.
Answer: (1) the probability to find a student taller than 175 cm is 8.5% . (2) In the school, 95% of the students are in the interval between 147.3 and 179.9 (or 163.6±16.3) cm in height.
RomanS wrote 06/15/2020 at 18:40 point
fantastic work done!
