New Assembly instructions and BOM purchasing info!
A project log for SmallKat: An adorable dynamics oriented robot cat
A dynamics oriented quadruped for research and education.
kevin-harringtonKevin Harrington 07/16/2019 at 20:360 Comments
Today was busy and productive! I printed out a new Grace model SmallKat and made an assembly instructions document. Check it out here:
https://github.com/OperationSmallKat/SmallKat_V2/releases/download/0.0.2/Catbot.build.instructions.pdf
In it you will learn how to assemble a smallkat robot, as well as calibrate all its links.
I also added the purchasing direct links on all of out BOM:
https://hackaday.io/project/164727/components
This should fill in the mystery steps in our previous documentation.
