Gear Calculations
I could not be bothered tying to work this out, someone has done it before, I just have to find it.
On my search journey I found the gear system we are using are call Epicyclic gears.
Anyway I did find a website that published the equation for this specific gear system (http://www.efunda.com/DesignStandards/gears/gears_epicyclic_train.cfm).
If the gear train is Na/Nb/Nc and Nd/Ne (i.e. Sun1/Planet1/Ring1 and Planet2/Ring2) where Ring1 (Nc) is fixed ,and the planets (Nb and Nd) are locked the the reduction ratio is:
- R=(1+Nc/Na)/(1-Nc*Nd/Nb/Ne)
Here is the worked example from the website:
Gear Train – Worked Example | |||
NA | 21 | Sun 1 | Driven |
NB | 61 | Planet 1 | Locked to Planet 2 |
NC | 141 | Ring 1 | Fixed |
ND | 41 | Planet 2 | Locked to Planet 1 |
NE | 121 | Ring 2 | Output |
Gearing 1 | 7.7143 | Check |
Gearing 2 | 0.2168 | Check |
Gearing | 0.0281 | Check |
Reduction | 35.5870 |
Here is Daren's design:
Gear Train – Daren | |||
NA | 18 | Sun 1 | Driven |
NB | 21 | Planet 1 | Locked to Planet 2 |
NC | 60 | Ring 1 | Fixed |
ND | 21 | Planet 2 | Locked to Planet 1 |
NE | 57 | Ring 2 | Output |
Gearing 1 | 4.3333 |
Gearing 2 | -0.0526 |
Gearing | -0.0121 |
Reduction | -82.3333 |
Note the sign change in the reduction ratio, this appear to be correct.
And here is my five planet version:
Gear Train – Alan v2 | |||
NA | 25 | Sun 1 | Driven |
NB | 20 | Planet 1 | Locked to Planet 2 |
NC | 65 | Ring 1 | Fixed |
ND | 20 | Planet 2 | Locked to Planet 1 |
NE | 60 | Ring 2 | Output |
Gearing 1 | 3.6000 |
Gearing 2 | -0.0833 |
Gearing | -0.0231 |
Reduction | -43.2000 |
Realisation
The gear design has migrated such that the requirement for the two planetary gears to have the same number of teeth is no longer valid.
AlanX
First stage is 3.3~:1 for mine, not 4.3:1.
Yes, the negative sign is correct. It switches directions depending on if the output has more teeth than the input or vice versa.
33:1 is a more workable ratio than the original. Good job.
Also, at this point you have contributed more to the project than 90% of all contributors I have had for projects. @Morning.Star is still winning in that regard, but the two of you may just change my mind about contributors... :)
