Laser Cut Single Stage Design
I was having problems working out the full MPRT laser cut design so I thought I would try a single stage design first. It is not that I could not design a laser cut MPRT, it is just that I was not happy with the design (i.e. too many layers). I know it can be better.
Actually even the single stage design was tricky. But eventally here it is:
The gray components are not necessary but useful for mounting.
So what we are looking at, starting at the bottom:
- The motor mount (the fixed arm), for different steppers I should add at least two more holes.
- The carry ring or output arm, (sun gear is actually on the next slice)
- The fixed ring and planets (offset for cutting)
- The upper carrier ring.
Notes:
- The gears and bolt hole have been adjusted (where required) for a laser cut width of 0.1 mm.
- The bolt holes are for M3 bolts but the final construction assumes the layers will be glued.
- It has been assumed a 2 mm dowel fixed to the planet will rotate in the carrier.
- And finally, the really small holes are for alignment pins (1.2 mm diameter by 25 mm long nails).
- The gear design is 5 turn (input) to 1 turn (output) for the single stage.
- I will wax the wood to reduce friction, may need to add a paper spacers to free up rotation of the carrier.
- The MPRT version (based on the current gear set) will be 55 to 1.
I have to double check the design measurements and lay it out for laser cut panel size.
Here is my laser cut laayout on a 600 mm x 300 mm 6 mm thick MDF board:
Next is to work out the MPRT version.
AlanX
agp.cooper
Yes, but part of the design problem is making the elbow stiff. That is why the single stage version has a "finger joint" layout. The arms are three layers thick in a four layer stack. This makes the arms x27 stiffer.
Also, the second layer has to a spacer or a carrier as the stepper mount bolts and the star gear hub are in the way. You also need access to the hub grub screw.
Finaly I need a way to retain the gears at the top of the stack, previously I used the a carrier. The "finger joint" layout solves this problem.
I can make the gear diameter smaller but I have to add another thin (2 mm) layer to the stack (after the stepper motor mount) to clear the stepper mount bolt heads.
Hopefully you can now see some of the design constraints.
AlanX
Very nice.
I think you can just bolt your servo mount and first ring gear layers together, and add a second ring gear layer.
