PiSugar2 in Beta
A project log for PiSugar Battery for Raspberry Pi zero
Portable Power Platform for Pi Zero
JdaieJdaie 11/25/2019 at 02:393 Comments
We start sending PiSugar2 beta last week for some friends to evaluate!
Since the springs are quite strong, which will make it not that easy to install as the previous version, we are considering solder four nuts on the pisugar board so that you don't have to align them while installing. The case has to be redesigned to adapt this.
The i2c address we are using is 0x32(RTC) and 0x75(power ic). I found that some led phats are using 0x75, it's a disaster to write something wrong on the power ic. But since it's i2c, it seems that we can prevent this from happening, just be careful when you have a 0x75 phat. (some phats allow you to change the address)
Ian wrote 03/29/2020 at 19:54 point
Do you need more beta testers ?? :)
Huân Đoàn Ngọc wrote 11/25/2019 at 17:24 point
Does it work with waveshare lcd hat(https://www.waveshare.com/wiki/1.3inch_LCD_HAT)? Im using SPI btw, so maybe it wouldnt interfere with pisugar2
Jdaie wrote 11/26/2019 at 09:20 point
No problem with SPI.
