μRetro game console with CPU on fake μSD cards
IT IS NOT ONLY GAME, IT IS NEW DEVELOPMENT INTERFACE.
CPU ( attiny85, atmega328 or samd21 ) on fake micro sd card :)
Thanks !
OSHPARK with 0.8mm service, ideal for micro SD card http://www.oshpark.com
PCBSIO to make beautiful black/gold boards https://www.pcbs.io/
PCBway for support with blue main board manufacturing https://www.pcbway.com/
Tiny85 card - https://oshpark.com/shared_projects/q9DnFbhb
Mega thanks to Daniel Champagne for games collection !
https://hackaday.io/project/165667-game-collection-for-attiny85
Hackster.io article this-tiny-retro-handheld-console-stores-games-on-fake-sd-card-cartridges
For years I searching any purpose for OSH park 0.8mm board service, finally I GOT IT !!!!
You can make fake micro SD cards
Main board carry speaker, display, power and switches,
CPU (attiny85) with game is on Fake micro SD card.
Dimensions: 2.4063 sq in (2.2127in x 1.0875in) / 1552.45 sq/mm (56.2mm x 27.62mm)
For more fun I have card with atmega328 or attiny85+DS3231 ... or DS18b20 (coming soon)
Working on SD card with STM32 and SAMD21
All game device have usually only one game, for change you need computer, now you can have unlimited games or apps, 1$/game.
Now you can found more than 20 games for attiny85
with 328 card you can play DOOM https://github.com/daveruiz/doom-nano
Or you can play games for ARDUBOY (working on compatible library)
Also you can use it as development platform micro SD interface can access to 8 wires.
  • GND
  • VCC
  • SDA
  • SCL
  • SPEAKER
  • ADC 0
  • ADC 1
  • ADC 2
Games come from genius Daniel Champagne
Project inspired with https://hackaday.io/project/159741-tiny-joypad
TODO:
  • 2x micro SD slot
  • port Arduboy games to Atmega328 card
  • direct display connection
  • suport for Lion battery and charging.
  • Design files ...
    bobricius05/07/2019 at 13:13 0 comments
    All is now on github https://github.com/bobricius/uRetro enjoy ;)
  • Raspberry PI card :-D
    bobricius05/04/2019 at 20:31 0 comments
    It is small joke ;) on card is also ADS1015 as ADC to read buttons ;)
  • Project name
    bobricius04/22/2019 at 19:00 7 comments
    Hi, Any idea about cool name for this console ?????
  • SAMD21 card
    bobricius04/12/2019 at 21:33 2 comments
    (12.8 x 30.6mm)
  • Dual Card ... Dual CORE :D
    bobricius04/11/2019 at 20:34 0 comments
    Main changes:
    • 2X parallel micro SD slots
      - 1. card MCU
      - 2. card SENSOR
      - you can also use 2x MCU and communicate over I2C
      - no care where is MCU or sensor, they are parallel
    • Display is direct on board not on module
      - WHY? until January I ordered on 4x on ebay by picture, I received 4x different display, with different pinout
      - you can put card from top side what is more practical
    • I will focus to keep all compatible with display module version, which is more DIY friendly
    • I think about microUSB for charging and add option for lion battery instead CR2032
    This is preview for board with 2 micro SD slot.
  • Game card with USB
    bobricius04/11/2019 at 19:37 2 comments
    After thinking and hearing community voices, kill 2 wires with USB is useless.
    So here is alternative with PCB USB (or metallic but this make board little longer).
    This require 0.6mm board, maybe this need little sticker to 0.8mm :)
  • support for CPU with USB ???
    bobricius04/11/2019 at 12:54 5 comments
    I got a tip from Mr. Vlk to try Microcontrollers with native USB and read buttons via I2C.
    Also Attiny85 can be reprogrammed via USB with digispark bootloader !
    My fake Micro SD give me 8 wires (list only, not exact pinout):
    • GND
    • VCC
    • SDA
    • SCL
    • SPEAKER
    • Analog 1
    • Analog 2
    • Analog 3
    Maybe in next version I can try this pinout:
    • GND
    • VCC
    • SDA
    • SCL
    • SPEAKER
    • Analog 1
    • D -
    • D +
    With this I can expand offer of usable controllers with etc. SAMD21 or STM32
    SAMD21 add now very popular Adafruit circuitpython programming feature ;)
    What do you think about it?
  • Console in my hands
    bobricius04/08/2019 at 22:48 5 comments
    For better dimension imagination ...
  • New cpu cards
    bobricius04/08/2019 at 22:26 0 comments
    Also second envelope is full boards from OSHpark
    What is new?
    • CPU reversed for deeper CPU insert
    • Card with Atmega328 for more hardcore games etc ARDUBOY emulation
    BONUS
    • Attiny85 breadboard adapter / programmer
  • New main board received
    bobricius04/08/2019 at 22:22 0 comments
    Good, news, I can work on upgrade.
    I am just received new main boards from PCBWAY
    What is new?
    • Card is more inserted and not stick up
    • +1 button ... 6 in total
    • power buton is moved to back (needed space for button)
    • all is prepared for port ARDUBOY games to Atmega328 card
View all 10 project logs
Keith Olson wrote 07/14/2019 at 04:52 point
Hmmm...  If you put two microsd card slots side-by-side, you could have cartridge PCB's that plug into both at once.  UART + I2C, perhaps on the second one?
Keith Olson wrote 07/12/2019 at 20:51 point
This would also make a *great* debugging interface for any other circuit.  All that is needed is a micro-sd extension cable and a cartridge with a breadboard header that has all of the lines--and probably some protection circuit.
Asher Gomez wrote 05/12/2019 at 02:53 point
Hey, @bobricius how efficient are the ATTiny SD Cards, and what are the limits of their uses?
bobricius wrote 05/13/2019 at 12:49 point
Attiny85 is best because all 8 pins are used on card, limits are like on another tiny85 (etc, 8kb flash, only 5GPIO = only 3 if you using I2C for display) based project. also onboard is space for mcu to use console without card.
Asher Gomez wrote 05/13/2019 at 13:08 point
Could they be used as an actual SD card for a computer?
bobricius wrote 05/13/2019 at 13:17 point
Of course no, this project use usd card only as mechanical connector. Pinout is partially like on real card.
Asher Gomez wrote 05/04/2019 at 22:05 point
@bobricius Have you considered fundraising this?
Asher Gomez wrote 04/28/2019 at 02:09 point
Congrats! You're at the top of Google!
Louis Irwin wrote 04/14/2019 at 19:48 point
Great project! Reminds me of an arcade console I made back in college...
RomanS wrote 04/11/2019 at 07:53 point
It's small and cool. Is it about 3х7см? Very interesting to see card with Atmega328 and arduboy game running on it )
bobricius wrote 04/11/2019 at 09:05 point
RomanS wrote 04/11/2019 at 12:28 point
It's a great idea to use this small fake SD cards with flash onboard. I think i'll add SD carf slot to my gadget the same way. Hope it's not to hard, just to connect slot pins to SPI )
bobricius wrote 04/11/2019 at 12:40 point
On fake card is not flash but complete procesor, It is much more versatile ;)
RomanS wrote 04/11/2019 at 12:50 point
incredible! ) but there are only 8pins. 2 for power, 2 for I2C, 4 for SPI (without CS)... seemes it's enough ) but probably better +2 for uart, +1 for led, +1 for sound ))
bobricius wrote 04/11/2019 at 12:56 point
Check my last LOG, what about D+ and D- from USB !!!!?
toxibunny wrote 04/10/2019 at 20:56 point
nice looking design!
Daniel Champagne wrote 04/08/2019 at 22:42 point
Good upgrade!👍
alireza safdari wrote 04/08/2019 at 22:36 point
could you please consider posting a picture where you hold it? It is so hard to imagine its size (not sure why).
bobricius wrote 04/08/2019 at 22:49 point
Of course, check now.
alireza safdari wrote 04/08/2019 at 22:50 point
Thank you. That was pretty fast.
My mind is blown away. I never thought it is this small. Great job!
fabian wrote 04/06/2019 at 10:27 point
interesting... is possible using fomu on this device?
https://www.crowdsupply.com/sutajio-kosagi/fomu fomu are faster and still need small power
bobricius wrote 04/06/2019 at 20:51 point
yes
Daniel Champagne wrote 04/04/2019 at 23:26 point
Wow! I just realized how tiny it is !!! UNBELIEVABLE!!!
Daniel Champagne wrote 04/04/2019 at 20:58 point
Awesome! A project really well done. I like the idea of the MicroSD slot. Too bad that there is not the little joystick that facilitated the gameplay. For the whole project, congratulations!
bobricius wrote 04/04/2019 at 21:11 point
This project is nothing without your games. I have plan send you one but I need some weeks for assembly. Maybe you make more games with this professional tool ;)
Daniel Champagne wrote 04/04/2019 at 21:18 point
Hahaha! With the growing interest in games for tiny Joypad attiny85, I intend to continue coding games for this platform. :)
davedarko wrote 04/04/2019 at 21:47 point
the "tiny bike" screenshot already looks awesome and I need to test "Tiny-Bert" on my now in resin encased skeleton handheld :) yes please, more games! :)
https://www.instagram.com/p/Bvt9p3SnhyY/
megazoid wrote 04/04/2019 at 15:28 point
I can't put my finger on it, but it looks familiar. Hats off to you though, the micro SD card solution is good. The edge card connector was something I always wanted to do, but couldn't source a suitable interface. I may need to rework a version 2 of #Tiny Joypad ;)
bobricius wrote 04/04/2019 at 20:33 point
I'd lie if I claimed I never saw a tinyjoypad project. Hackaday is all about inspiring, your idea was brilliant, I improved it. Now it's your turn ;)
Daniel Champagne wrote 04/04/2019 at 21:24 point
👍👍👍👍👍  I like this philosophy!  👍👍👍👍👍
bobricius wrote 04/05/2019 at 06:13 point
Every day I fight the feeling I'm just a thief. But the whole world is now built on robbing. When I don't know what to invent, I will improve other inventions.
Daniel Champagne wrote 04/06/2019 at 00:59 point
bobricius Do not worry! Regarding the tiny joypad you did not steal the plan that I publish is distribute under GENERAL PUBLIC LICENSE v3. All projects resulting from it governed by the same legacy license! As long as you mention the original author and provide the original source, as you already did very well on your page. ;)
AVR wrote 04/04/2019 at 08:13 point
this is pretty damn cool, first of these things to have its own catridges from what I've seen, nicely done!!!
davedarko wrote 04/04/2019 at 07:49 point
Woah, this is awesome! I recently dabbled with the games of @Daniel Champagne myself :) Found it through #Tiny Joypad and used it to update my #Skeleton Attiny85 Handheld  What did you modify the schematics aside from your SD card mod? And is it already on @Tindie ? Good luck with the price!
