Main changes:
- 2X parallel micro SD slots
- 1. card MCU
- 2. card SENSOR
- you can also use 2x MCU and communicate over I2C
- no care where is MCU or sensor, they are parallel - Display is direct on board not on module
- WHY? until January I ordered on 4x on ebay by picture, I received 4x different display, with different pinout
- you can put card from top side what is more practical - I will focus to keep all compatible with display module version, which is more DIY friendly
- I think about microUSB for charging and add option for lion battery instead CR2032
This is preview for board with 2 micro SD slot.
bobricius
