Based on Roger's original project for SAWPPY:
https://hackaday.io/project/158208-sawppy-the-rover
Mechanical build is straight forward due to very detailed instructions.
In my case, I used a "Anycubic i3 Mega" Printer and PETG filament from Amazon. Since it was the first time I worked with PETG it needed lots of testing to figure out working settings on my printer. At the end of the day everything went fine and totally confident PETG as a solid material.
I’m just figuring out Hackaday itself, so updates and more informations will come step by step ;)
Hi there,
nice rebuild! I also want to build one. Do you mind if you could tell me, how you acquired the aluminum extrusions? As far as I know Misumi in Europe does not deliver to private buyers, only to corporations.
This is my current dead end, since I was not yet able to find another supplier for the 15x15 beams with the same slot dimensions. Can you give me a hint? Thanks in advance!
