Improvement points
A project log for Simple bipolar full step driver
A simple bipolar step motor driver, the goal here was to use simple components, without any dedicated IC, and produce a single layer PCB
gabriel-despindulaGabriel D'Espindula 04/04/2019 at 12:250 Comments
The project works well, I would change a couple things for the next version:
  1. Add a diode or P-Channel MOSFET to avoid inversion of the power supply;
  2. Change the input connector's silk, the way it is all wires are in front of the text, would be better to see the signals even with the wired hooked up.
