5. Resultados / Results
A project log for Generador Diodal ( Diodal Generator )
...aprovechar las cualidades fotovoltáicas de los diodos / take advantage of the photovoltaic properties of diodes...
chkymschkyms°> 04/05/2019 at 15:320 Comments
... el circuito sin resistencia produce 11.59V : no he podido medir la corriente...
...circuit without resistance produces 11.59V : haven't been able to measure current...
...con un LED azul el voltaje baja a 1.71V...
...with blue LED voltage decreases to 1.71V...
