Experimenting with FZT851 transistor
A project log for Easy Open Tesla coil on PCB
Very simple Tesla Coil - 3 components only = LED, BUL45D2G transistor and 82K resistor
bobriciusbobricius 04/18/2019 at 20:540 Comments
At first I burn almost all transistor after power on, then I test lower voltage than 36V like for previously tested BD243.
FZT851 at 12V without LED:
FZT851 at 12V with red LED:
RESULT:
Subjective I think, I have almost same results with FZT851 at 12V like BD243 at 36V
FZT851 is SMD in SOT223 package, is more sensitive and is harder for cooling.
You can see some neon glow on 5-6V.
