Pajamas micro Laser Engraver
CNC test build for super small desktop Pick & Place or Laser, no custom parts, just standard components, I am building in sleepwear
Why Is it small???<br>- I have small desk<br>- 20cm extrusions + linear rails are cheap. For testing it not eat much money<br><br>What is special ??<br>- almost no tools required or drilling<br>- core-XZ (H-bot version) for movements, both motors fixed, fast&amp;light gantry<br>- You can mount MGN7 linear rail directly on MGN9 carriage, but you need enlarge<br>holes on MGN7 rail because they are 2.5mm and on carriage is M3 holle.<br>It was the only one time that I need to change clothes and use drill in garage.<br><br>More pictures on my personal page go to LASER ENGRAVING <a target="_blank" rel="noopener noreferrer" href="http://www.pemi.technology">www.pemi.technology</a>
Vector mode:
Scan mode:
Now testing:
  • 3,5W blue laser or maybe 2W how I can trust Chinese label?
  • Cut 3mm Acrylic 2 pass 10mm/min
  • Cut 3mm Plywood 2 pass 200mm/min
  • Engraving on any speed, you can adjust how many smoke you need in room
  • working area 110mm x 135mm
  • H-bot gantry movements
I am satisfied :)
gift_boxes.zip
Gift boxes optimized for diode laser
x-zip-compressed - 364.01 kB - 05/26/2019 at 21:26
Download
View all 7 project logs
jackantubis wrote 10/31/2019 at 14:16 • point
Nice, where do you find your red shield ? thanks
Andy wrote 05/09/2019 at 05:06 • point
Interesting project :)
Just for the information, what is the price of this device, if it's not a secret. Are you going to publish some contraction plans?
bobricius wrote 05/09/2019 at 05:51 • point
My wife must never know! around 100-300$ hard to say I ordered many parts form various aliexpress sellers, I am not sure if I use all, some parts I have form old project. I thing is cheaper to buy some chinese kit. My solution is more compact, on linear rails, and I can cheaply replace any part. The main advantage is that it is a compact cube that will soon will also have side walls and exhaust smell outside. I do not have any plan I just sat down 2-3 evenings in pajamas on the floor tried as what fits together.
Jonathan wrote 05/12/2019 at 06:09 • point
hi,
I have tested one of chose Chinese kit you can buy on eBay for 250$ with 2,5w and 5w laser and i had similar result. I just bought a carbon filter with a good fan to avoid the smeel in the room ;-)
Vincent wrote 04/30/2019 at 20:11 • point
That is really cool stuff!!
