For Thor I want to use a USB host controller that connects to PS3 but I ended up having a issue that may become dangerous when operated on machinery: ps3-controller-i2c-concerns
I was wondering if the issue was because I used a Arduino Due and 3.3v (Ultratronics board for the Thor project) but I can now repeat it also on a Arduino Mega in both 5V and 3.3V.
The original test has a blinking LED when I press a certain button so I am sure that it is not the serial stream that is causing the issue.
Grabbing a trace shows this results and it is clearly a firmware issue.
The PS3 data is 35 bytes long so it must be read into 2 parts. First the 28 bytes, then the next 7 bytes.
What we observe here in the tracing is that the next 7 bytes sometimes are actually part of the first 28 bytes.
The rectangle button is part of the second 7 bytes and I have now an explanation why I had more stable functioning when I only used a button in the first 28 bytes.
Executing code below.
void get_ps3()
int bytesToRead = 28;
// Get data from PS3 DualShock Controller
// We only want single byte values (0 to 255)
// We use a pointer to the ps3 struct we defined so we can populate the data in sequence
uint8_t *ps3Ptr = (uint8_t *)&ps3; // Create pointer to ps3 struct
unsigned char data_values_rcvd = 0; // keep track of how many characters received
Wire.beginTransmission(I2C_ADDRESS); // transmit to device
Wire.write(0); // Start receiving data from register 0
Wire.endTransmission(); // end transmission
// To retrieve all data we need 35 bytes, but restriction in Arduino means
// we can only get 32 bytes at one go, so we split it into 2 reads
Wire.requestFrom(I2C_ADDRESS, bytesToRead); // request 28 bytes from PS3
while (Wire.available())
*ps3Ptr++ = Wire.read(); // receive a byte and increment pointer address
data_values_rcvd++;
Wire.write(28); // Start receiving data from register 28
Wire.requestFrom(I2C_ADDRESS, PS3_DATA_SIZE - bytesToRead); // request outstanding bytes from PS3
data_values_rcvd++;
Interesting is that when I pull the blue-tooth transmitter from the USB host controller the random data data goes away.
UPDATE:
It was suggested that in the trace lines I grabbed there was a missing CR+LF. But it is not. If you count the number of values than they are 35. It is just that value [29] and higher contains values that should be 0 or 1 but never higher. The offset you see is the fact that some numbers are 3 characters wide
