ART1BOT in NGEN filement
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 11/11/2017 at 19:533 Comments
Test of ART1BOT this time printed in NGEN filament.
It printed without any hiccups on my 3D printer nor warping. It feels very solid and the details are pretty good.
Detail of the cogs
The rim is almost not bendable, and will splinter when pressed to hard.
Bottom part (actually this is the upper part in the Thor robot). You can see that support structures left some fragments behind. The object does have sharp edges, something I did no have when using ABS. But these sharp edges are easier to get rid of wit sand paper. Easier than ABS.
Sepio wrote 11/12/2017 at 17:33 point
In Cura I like the “concentric” support structure. This can be removed easily.
https://ultimaker.com/en/resources/20422-cura-support-settings
dannyvandenheuvel wrote 11/11/2017 at 21:50 point
looking good, supports will be a little harder to remove. Use dense in simplify3d and try to make a space between it by adding one layer not printing.
Olaf Baeyens wrote 11/11/2017 at 22:48 point
Upper vertical  separation layers?
I will try to play with these settings next time... I have a working Sunday day tomorrow
