Sepio's version of Thor upper parts
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 12/11/2017 at 00:393 Comments
Started to print the Thor upper part I have found created by Sepio: https://hackaday.io/project/26341-building-and-improving-the-thor-robot-arm/log/70087-day-18-redesign-of-art3-and-art4
I needed to reprint the part because I need cooling, and it is a great way to test NGEN how it performs with bigger objects.
I like Sepio's upper part, it looks easier to assemble and has a fan included to cool the upper part.
The Art 3 lower body. 0.3 mm layer heights, Simplify3D estimated this a 7H job but it turned out to be 8H45. You can see the support structures that actually came off very easily.
Inner part of Art 3 lower body.
The day before I tested 3 different materials I received on Friday.
I started with the part that guaranteed failed every single time I used ABS.
All 3 jobs are 2 hours printing.
Top parts
Bottom parts
That test concluded me to go for NGEN when I print parts for Thor.
Sepio wrote 12/11/2017 at 11:55 point
Are you going to build 3 robot arms ;-)
Olaf Baeyens wrote 12/11/2017 at 12:38 point
One is enough, this was just a test.
Sepio wrote 12/11/2017 at 12:41 point
I just uploaded the latest version of the arm. Look at build log 20.
