Improved PCB ESPboy.pro v2.1
A project log for ESPboy: beyond the games platform with WiFi
for games, IoT experiments, education and fun Arduino ecosystem compatible, 30x70mm, ESP8266-80Mhz-4Mb, display, RGBled, buttons, HQspeaker
RomanSRomanS 04/12/2019 at 08:312 Comments
ESPboy.pro v2.1 improvements.
The PRO version is rather complicated and i think it will be sutable only for hardcore geeks :)
For regular users it's better to take EDU version!
1. 2 side buttons added for more comfortable horizontal usage
2. Micro SD card slot added
3. GROVE sensors jack added
4. Some tracings improvement
RomanS wrote 04/14/2019 at 20:00 point
it's clean side ) Wemos esp8266 is on the another side. on this side should be a battery and if somebody needs SD card reader, it's possible to solder it and then battery will be above. so SD slot just add about 1mm thickness overall
bobricius wrote 04/14/2019 at 17:01 point
Are you sure with removing SD card over pin header?
