ESPboy - RetroGaming&Software development MuliTool
For IT geeks, retro game fans, makers. Open source, portable, modular to explore, create, learn, code & play
Starting from
$99.00
ESPboy_edu has 55 orders / 3reviews
Ships from Kazakhstan
ESPboy2 - retro gaming, pentests, IT and IoT experiments multi-tool
www.espboy.com
- Open source, open hardware, portable, modular
- To explore, create, learn, code & play
- Empowered with AppStore and community support
- WiFi onboard, 100% Arduino IDE compatible
- Could be:
-- prototyping and developing platform for makers and IoT experiments
-- a retro game console (supports Little Game Engine, GameBoy, ZX Spectrum 48k, Arduboy, CHIP8/SCHIP)
-- WiFi analyzer/packet sniffer/attacks detector...
- Uses ESP8266 microcontroller (Xtensa Tensilica 32bit core, 80/160mHz, 4Mb) and has built-in WiFi, 8 buttons, RGB led, high-quality speaker, extension header
- With attachable extension modules turns to any portable gadget in a minute
-- weather station
-- IR blaster
-- FM radio
-- MP3 player
-- LORA messenger
-- GPS navigator
-- GSM phone
-- Radio beacon
-- Sub1Ghz inspector
-- RFID/NFC reader
-- AY player
-- and more
Have fun with ESPboy
ESPboy is open-source (most software is under MIT license) and open-hardware (CERN license) project.
OSHWA certification record
Openhardware.io record
ESPboy is a science, technology, engineering, and mathematics [STEM] learning platform which encourages and enhances creativity, imagination, and ingenuity through project-based learning and reverse engineering.
ESPboy is ideal to learn game development, internet of things, start programming, understand how gadgets work, and try robotics basics all with the community help.
It's a fantastic experience to assemble the ESPboy yourself or together with your child. Make your own games and apps, share them with the community online. You can make any fully functional gadget in a minute with additional modules, play with it, understand the way of work, modify it and create the unique new one!
It's about fun engineering education and creativity through limitations :)
ESPboy utilizes a powerful ESP8266 microcontroller with built-in WiFi, Arduino IDE compatible with tons of libs and professional firmware and SDKs
Simple schematic (for detailed schematic, ESPboy+casing PCBs and Gerber files please check project page at www.easyeda.com
Connecting the original modules to the ESPboy's header and updating software through WiFi, you'll get fully functional gadget in a minute (LORA messenger, weather station, GSM phone, FM radio, MP3 player and more)
"ESPboy App Store" with a load of games and applications available through your WiFi network connection. It’s free, online, and works fine directly from your ESPboy
WiFi analyzer & packet sniffer
Create games with "Little game engine", "ESPiCo game engine" or any other framework
Play old retro Nintendo Game Boy games like Zelda, Super Mario etc...
Try ARDUBOY retro console emulation with excellent Arduboy2 game creation library ported. It will take just few minutes to recompile any game from Arduboy to ESPboy )
Play retro Chip8/Superchip games. It's an true digital heritage from the 70s with CHIP8/SCHIP emulator. Try new modern games from the OCTO jam.
Have fun with retro ZX Spectrum 48k gamesfrom the 80-90s using zx48 emulator.
Listen the portable FMradio, MP3s or WiFi radio with ESPboy modules
Listen the retro AY38910 chip synth music with DAC module
Write programs or chat in messengers using keyboard module
ESPboy has WiFi onboard to:
Specification:
View all 8 components
View all 117 project logs
  • 1
    Check the video build instruction
  • 2
    ESPboy Kit and parts
    You can get ESPboy Kit with partially preassembled PCB where is soldered most of small components.
    Only 3 modules and speaker should be soldered in following order:
    1. speaker (as you can see on black PCB pictures, not buzzer, as at red PCB pictures)
    2. TP4056 battery charging module (don't forget to replace R3 resistor according the following info)
    3. WeMos D1 mini (LOLIN) microcontroller module
    4. LCD display module
    Official ESPboy Kit:
    PCB with most of small components presoldered
    Or you can order the ESPboy PCB or buy it clean and also buy all components separately
  • 3
    ESPboy assembly tools
View all 12 instructions
Roberto A. Foglietta wrote 01/21/2024 at 14:45 point
Hi @RomanS , I wish to receive some information about the keyboard module which is depicted into some image but not listed into components BOM. Can you help me to find it on the market please? Thanks, R-
RomanS wrote 04/25/2024 at 06:10 point
Hi. It is blackberry q10 keyboard
Nazwa wrote 06/04/2022 at 22:07 point
fuzix os can run on this device? (meybe external keyboard must be added)
RomanS wrote 06/05/2022 at 05:26 point
as far as i see there is a ESP8266 port of fuzix os https://www.cnx-software.com/2021/02/23/fuzix-unix-like-operating-system-ported-to-raspberry-pi-pico-and-esp8266/
RomanS wrote 06/05/2022 at 11:25 point
the core of ESPboy is ESP8266 and i see the fork of the fuzix os for ESP8266 so, yes, its possible
Nazwa wrote 06/10/2022 at 14:34 point
can You show a video?
RomanS wrote 06/12/2022 at 11:56 point
I haven't checked it myself, but you can google it.)
kwapiszon wrote 11/16/2020 at 10:39 point
i prefer a joyistick like a chinese console game
for tempest game and for volume a potenciometer
how long this device work on one charge?
RomanS wrote 11/19/2020 at 18:36 point
"how long this device work on one charge" depending on many factors. wifi, LCD brightness, sound. few hours till few weeks if it uses sleep mode for IoT. "i prefer" you can always make your own deice )
Nazwa wrote 06/04/2022 at 22:09 point
Ii prefer yoistick, knob too ( or other analog input data not only keys)
this sugestion is very important if the keyboard have only 6 keys
for example this yoistick https://powkiddy.com/products/powkiddy-rgb10-max-handheld-game-players down/left is better than only 4 keys for walking trought menu
RomanS wrote 04/25/2024 at 06:12 point
ESPboy is not designed for gaming )
morgan wrote 01/14/2020 at 00:21 point
Really love those brass screw button caps, nice touch.
RomanS wrote 01/14/2020 at 06:37 point
Jacob MacLeod wrote 10/06/2019 at 11:01 point
This is really cool!
RomanS wrote 10/10/2019 at 08:19 point
thanks!
Jacob MacLeod wrote 01/13/2020 at 09:32 point
When do you think a kit will be available?
Also, what sort of price do you think of will cost?
RomanS wrote 01/13/2020 at 15:41 point
I have to finish with formalities to start selling. Hope it will take a couple of months. The price will be about the same as similar projects on the market I suppose... Anyway, there is also the way to DIY ESPboy for the lowest price. All schematic, software, instructions are available free.
Jacob MacLeod wrote 01/13/2020 at 22:36 point
Right... so if I order the PCB at JLC PCB and use the SMT tool, what components are presoldered, and what components do I need to buy myself(from aliexpress/ebay/Amazon/LCSC)
RomanS wrote 01/13/2020 at 22:48 point
The components JLC can presolder is the question to JLC i think ) i don't know. Probably the easiest way is to order at JLC just PCB and all other parts separately from aliexpress/ebay/Amazon/LCSC/Mouser Electronics/digikey/etc...
Jacob MacLeod wrote 01/13/2020 at 22:58 point
Ok... the build guide shows that some parts will be presoldered in the kit. Which parts are these?
Ken Yap wrote 01/13/2020 at 23:24 point
JLCPCB is a sister company to LCSC so presumably they can presolder anything that LCSC sells. However there are minimum quantities for items ordered from LCSC, but maybe this doesn't apply to presoldered components.
RomanS wrote 01/14/2020 at 06:23 point
According to my JLCPCB order, they agreed to presolder all small parts, but it costs. Buttons (8), MCP23017, header, all resistors (4), variable resistor, fuze, slide switches, RGB led, MCP4725. So the rest (wemos d1 mini, charging module, LCD, speaker) you have to solder by yourself. But remember that you can assemble a simple breadboard version of ESPboy with just few components and without soldering.
Jacob MacLeod wrote 01/14/2020 at 10:15 point
Ok... how hard is it to solder small SMT components? Is it very different to larger through-hole components?
RomanS wrote 01/14/2020 at 10:34 point
it's better to try the SMD soldering to understand ) more experience, easier and faster result. there are a lot of videos about this process at youtube
Peabody1929 wrote 07/30/2019 at 21:16 point
Is there a kit available?
RomanS wrote 10/10/2019 at 08:20 point
soon at tindie.com i hope
bobricius wrote 04/14/2019 at 17:00 point
Wat you think about much modern ESP32? more gpios, save expander, ble, touch, better power management. Official arduino support, mp3 playback, 2x analog out???
RomanS wrote 10/10/2019 at 08:22 point
Too much devices are aleready on the market with ESP32 theese days )
