ESPboy Sub1Ghz frequency scanner
A project log for ESPboy - RetroGaming&Software development MuliTool
For IT geeks, retro game fans, makers. Open source, portable, modular to explore, create, learn, code & play
RomanSRomanS 12/05/2021 at 10:220 Comments
Scan the radio band in the defined limits 300-348 MHz, 387-464 MHz and 779-928 MHz, as long as the CC1101 chip allows. Select the desired frequency and pitch. Easily determine the frequency of active radio signals around you.
Source code https://github.com/ESPboy-edu/ESPboy_Sub1GhzScanner
