PT3 player with AY-3-8910 sound chip emulation with DAC module
A project log for ESPboy - RetroGaming&Software development MuliTool
For IT geeks, retro game fans, makers. Open source, portable, modular to explore, create, learn, code & play
romansRomanS 12/15/2019 at 20:140 Comments
It's a PT3 format chiptune music player written by Shiru for ESPboy project. The format is a kind of standard de-facto for AY-3-8910 chiptune music. This chip and its analogs have been used at:
About 25000 songs have been made since the mid-90s when it was first introduced.
The program emulates AY sound chip and plays PT3 files loaded into the SPIFFS. The sound is output through the sigma-delta modulation based DAC via the built-in speaker. It also supports I2S stereo DAC if connected (change define in the sketch, no run-time option to switch between outputs at the moment).
You can see and hear at this video the ESPboy DAC module play of few melodies from Shiru.
Check the following links to get much more music:
More related links:
  1. ESPboy community PT3 play thread
  2. Shiru's youtube
  3. Shiru's involvement in ESPboy project
  4. Shiru's albums
  5. Shiru 1bit music news
  6. 1bit forum
  7. Shiru's Stuff
  8. PT3 play source on GitHub
