Sub1Ghz Inspector CC1101 module
A project log for ESPboy - RetroGaming&Software development MuliTool
For IT geeks, retro game fans, makers. Open source, portable, modular to explore, create, learn, code & play
romansRomanS 10/29/2020 at 07:050 Comments
ESPboy Sub1Ghz Inspector CC1101 module uses powerful CC1101 transceiver to listen, record, and replay the radio signals range 300-348 MHZ, 387-464MHZ, and 779-928MHZ.
This allows you to copy and clone the radio signals sent out and received by the most popular low-cost power outlet sockets and light switches.
Do not use it for copying the garage doors, gates, and barriers control signals, it's against the law and private property.
Source code
