DLT one - A Damn Linux Tablet!
Modular Open Source Hardware Tablet that is easy to hack and can run a standard Desktop Linux Distribution (or Android)
Proper Linux Tablets unfortunately just dont exist and certainly not ones that are also open hardware.
I want hardware that does not lock me into a specific OS or cripples other options by the lack of drivers. I'm also sick of the lack of modularity and repairability of modern hardware.
So I will create the following.
A basic system for a modern and highly performant portable device (e.g. Tablet) in the 7-10" form factor.
The electrical and mechanical design will allow for a multitude of form factors in the future, basing on a shared approach on how to interconnect hardware, so reuse between form factors will be possible.
These newly developed standards for modular portable devices will be open to everyone and the same goes for the design of the Tablet that is being developed here.
For more details please read my project logs and the detailed description below.
The development started with the HaD Prize 2019 and you will be able to follow every step of it.
Motivation:
For years I've been wanting to create a tablet like device based on a SoM (System on Module). Doing something from scratch, routing DDR3 RAM, eMMC etc. didn't seem realistic to me, this is not only really hard but also very expensive. So SoM it is, which comes with the additional benefit of user upgradability if the SoM manufacturer stays true to their pinout with successor products, which they usually do if the SoM is in any way meant for an industrial market.
Back then I started out with the Raspberry Pi compute module but the more I thought about my specs the clearer it was to me that it just wont cut it.
I wanted something that can run modern applications, something that is actually very usable and is not just a cool thing on paper.
The past years I've been looking around for affordable SoMs that offer enough performance to be viable, until now there were either cheap outdated SoMs or ones that mainly target the industrial market and are too expensive.
In recent months there is finally an interesting selection of SoMs out there.
Technexion/Wandboard released the Pico SoM product range and the Pico Pi as a dev board. They range from 72-150$ For 150$ you get a fairly decent ARM SoC with 4K video support, 4GB RAM, 16GB eMMC and 802.11 AC WIFI and Bluetooth 5.0.
Essentially the basic specs for a modern tablet.
The other SoM that just popped up recently is the Nvidia Jetson Nano. Very capable SoM with similar specs but lacking WIFI. Though the GPU is much more high-end than the iMX8M Quad.
Another very important part is the Display. Until now I never found a satisfying product that had a good picture quality and resolution. It just feels wrong to use a 800x480 display in 2019.
For some reasons there are really great IPS displays popping up all over the place from 1.8" to 13" there is something in every category and all of them can be considered to be "retina" displays. If I want to make a tablet I don't want it to feel like tech from 10 years ago.
So the goal is to make it good or go home :)
What this project will then essentially entail is to design a carrier board for one the two SoMs (though I want to see if I can keep it generic enough to allow for different SoMs in the future) and create a mechanical design that will fuse display and carrier in a visually pleasing way while maintaining the goal of hardware modularity end reusability.
What:
My MVP will have the following specs:
  • Fast enough SoC/SoM to run a modern web app without lag.
  • Enough RAM for more demanding applications >=2GB
  • 802.11AC Wifi and Bluetooh
  • USB for charging and data >=USB2.0
  • High-res display in the 7-10" range connected via MIPI DSI or eDP.
  • Modular peripherals, the carrier should be very small allowing different peripheral connectors to be attached through FFC cables. A choose your own peripheral kind of product.
  • A parametric case design that allows for different screen sizes and peripheral openings.
  • Battery and charging circuit. No idea how large but I aim for around 4h+ active usage for now.
  • Extensible storage via SDcards
  • Audio
  • HDMI
Cool things for the future:
  • USB-C PD
  • Desktop peripherals that you never see in mobile products like an Ethernet Jack.
  • mPCI-E connector ( I never touched PCI-e so lets see how that goes). This would technically also allow for M.2 and adding a proper SSD to your tablet.
  • This does not have be a tablet, if I can make it small enough a phone is also possible, at least a phablet.
  • USB 3.0+
  • LTE either through USB or PCI-E
  • Camera
  • Keyboard "dock" to turn it into a Laptop
Here is a block diagram of what I'm looking to develop, this might change slightly in the future as the design progresses.
Visualization Images Courtesy of:
Wise Technology
Nvidia
ICs and other hardware parts are generously sponsored by MESO Digital Interiors https://meso.design/en
  • Peripheral Bezels
    Prof. Fartsparkle08/13/2019 at 21:58 3 comments
    These are a solution to the fully customizable tablet version. If you read the project log about manufacturing I talked about having two different back cover plates essentially. One that is monolithic and neat, only usable for a fixed pre-selected set of peripherals.
    The other would be the hacker, maker, researcher option that lets you fully customize position and amount (and kind) of peripherals, making it also easy to add you own custom hardware.
    The issue I had to tackle was how do you achieve this without having open sides or requiring 3D printing from the customer.
    This is the solution I came up with (pictures below). Each peripheral will have to choose a bezel size. I haven't decided how many I want to include in the mechanical standard yet but it will probably be around 2 size options. They will only be allowed to differ in width, not height. Height is fixed for every element.
    To close of the space between peripherals we have spacer blocks, they come in the same widths as the bezels, so if you have give amount of spacer blocks you can always make a closed side surface, even if you add your own peripheral, all it has to do is adhere to this mechanical standard.
    The raster length is always a multiple of largest block width. The corners help define this, without them you will run into issues with different screen sizes, so the corners will always extend into each side of the tablet until they form this fixed raster length. That way you can adapt this to any screen size up to a certain minimum size given by the block width.
    Finally some pictures of the prototype prints that I made for illustration. This will of course look much much nicer with injection moulded pieces and an aluminium mounting plate instead of clear acrylic :)
  • Mounting plate mock-up
    Prof. Fartsparkle08/07/2019 at 22:14 2 comments
    I made a rendering of this before but I now laser cut a mock-up out of acrylic (the real deal will be aluminium).
    It's purpose is mostly to test out how well the positioning of the peripheral works out and to experience any issues when working with a real display and PCBs. It's also the first illustration of the whole modular peripherals idea.
    The result was quite promising. I also realized that I could slim down the thickness of the shim layer which raises the mounting plate high enough so it can sit just above or on the back of the LCD. I had concerns because there is always a part of the LCD that is thicker than the rest where the connector comes out (usually all covered up with black tape). I can just leave a cut-out there as the touch screen offers enough supporting area and lower the overall height of the shim. Here a picture of the whole mock-up assembly.
    Placing the peripherals worked pretty well! The hole raster on the edge (and to a degree in the middle) is all threaded 2.5MM holes in a 5mm pitch. This gives nice even distances of 5mm increments for both positioning as well as hole placement on the peripheral PCBs.
    Here a few close ups of some peripherals
    It is crucial that pure SMT components are used for this. With hybrid components like this HDMI connector below, you need spacers to raise them enough, those spacers are a bit too much but still, it will always add a 1-2mm to the overall thickness of the assembly.
    This hopefully illustrate how the whole modular peripheral concept is supposed to work. This is of course an early stage but it shows where it is supposed to go.
    As you can see there is always a slight offset from the edge for each PCB. This space is intended for the faceplate that each connector will receive and will make for closed side surface, even with a modularized back instead of a pretty but fixed injection moulded back.
    I will print mock-ups of these face plates in the coming week. So the next update is hopefully showing those off.
  • Problems with revision 2
    Prof. Fartsparkle08/07/2019 at 21:58 0 comments
    Unfortunately the new revision had quite a few issues that I was not expecting. Revision 2 was largely a form-factor change, the circuitry was tested with the SBC style PCB in the first revision.
    So what changed? Mostly that peripheral and most of the circuitry went on their own little PCBs and are connected via FFC to the mainboard which now has a much more reduced circuitry, that brings costs down for the mainboard and you only pay for the peripherals that you actually need, this also enabled a free positioning of the peripherals but more on that in the next update.
    Back to the mainboard. When I powered it on with Ethernet attached I got no device showing up in the network unfortunately. When I attached the serial console I got at least a boot log so things were actually running but it seemed kind of flaky, I often didn't get a login prompt at the end of the boot process. At the time I was thinking I was having power issues but in retrospect I think this was just a bug in an older version of JetPack (the OS for the Jetson, a modified Ubuntu).
    I turned to the schematics and realised that the pinout on the Ethernet FFC connector was shifted by one pin to the right...
    The same happened to the USB which I tried next with an Ethernet dongle but had not luck either for the same reason, pins were offset.
    I was really puzzled about how that happened until I realised that the tabs of the connector which carry no signal were on the same side as the actual data pins on the schematic. When I mirrored the pinout I just mirrored it and applied it to the connector again in reverse order. The issue was that I included the tabs in that process and assigned them a signal instead of the GND connection...
    Oh well, fortunately not the most important peripherals for now and I learned a (circuit) life lesson.
    The eDP and HDMI connector pinout were fortunately all good, I took a bit more time on those and didn't rush them out in day like the other peripherals.
    Unfortunately they didn't work either. At that point it got quite frustrating, I went from a 100% working revision to a 10% working revision.
    I quadruple checked everything, first thing I found was that I missed the eDP hot plug signal, it got renamed in the whole moving process. This was quickly fixed with a bodge wire. At that point the Jetson tried to establish a connection with the display and did seem to communicate but always failed during the link training process which establishes certain ground rules with the display for how the connection will be handled. The equivalent to this in HDMI is the EDID readout with the addition here that there is also some negotiation about the amount of signal lanes to use and other timing related things.
    I did not get any further with this unfortunately. I tried wrapping my FFC cable in copper foil to shield it. I used shorter DisplayPort cables. Nothing worked. I got contacted by a person from Nvidia that also already helped me before with design resources, so hopefully I will get some more insight there of what might be wrong. Again, the circuit did not change, its all the same.
    HDMI was a similar situation, EDID read fails but fortunately the Jetson goes into a default resolution for the HDMI for some reason if it can't read the EDID and this gave me a picture! So that at least hints that its not an impedance issue introduced with the FFC cables.
    Why does the EDID read fail? I do not know, I checked the circuitry surrounding the I2C signal level translation but could not find any issues introduced with the move.
    It is interesting though that both fail at a similar stage, the EDID readout / link training.
    I tried the actual eDP PCB which connects to the eDP panel instead of a DisplayPort display. Unfortunately no difference, here I get even a stranger behaviour, the Jetson does not boot at all. When I unplug it and reset it is booting fine again. Hot-pluging it 'works' it atleast doesn't crash the system and yields similar edid / link training error messages as with...
  • Revision 2
    Prof. Fartsparkle08/07/2019 at 21:25 0 comments
    I've been busy the past few weeks.
    I held back a bit with this update as I wanted to get certain things finished and some things debugged first (which wasn't successful yet).
    You could follow along with my daily struggles on twitter if you are interested in more regular updates. I use this blog more for the condensed version every couple weeks.
    The boards arrived a while ago from JLC, again in matte black which now comes at no extra cost which is quite nice! I know PCB business cards are a bit dated by now but you could get them now in glorious matte black for 2$ which is just insane...
    They were also supportive and sponsored a large part of the order which I think was the largest PCB order, in terms of different designs, that I've ever done...
    Here a shot of all of them together.
    I got to populating the mainboard first, here a few shots of before and after reflow.
    Got quite a few shorts which was annoying but nothing that the soldering iron couldn't fix.
    Except for this little fellow which gave me quite a headache before I discovered it. It was shorting 1.8V with 3.3V...
    And another shot of an HDMI peripheral board as well as Ethernet (not really considering Ethernet for a final version but its great for debugging)
    So how did it go you may ask? Not very well unfortunately. More on that in the next post (which will come out in just a few minutes)
  • Manufacturing and the target audience
    Prof. Fartsparkle07/08/2019 at 23:17 4 comments
    A topic I haven't talked about in too much detail yet.
    Its something I'm constantly thinking about whenever I change something in the design. The tricky part is that I want to reach two main target audiences which require somewhat conflicting mechanical design.
    The first one being the general open source crowd, no matter if they are interested in hardware or not, there is quite a lot of interest from people who are interested in Linux and open development. They mostly want to see a tablet that comes close to a polished commercial tablet, from the feedback I've got it seems they are fine with something thicker but it didn't seem there was a ton of interest in fiddling with hardware or getting something that works but looks ugly. Small to mid sized industrial companies are also pretty interested in something like this, they would require a more rugged case and are also fine with thickness but also require a finished and polished product that is well integrated.
    Catering to this crowd is actually not hard, you require a few injection moulded pieces of plastic (I try to keep it as simple as possible, so far I see about 2-3 large pieces of plastic) and make a design that is constrained and tries to squeeze the hardware into any space there is to yield a tablet that looks nice and tidy, just as a tablet would look like that you bought from the usual Manufacturers. Sure there will be a few iterations until it comes out perfect but injection moulding is a well understand process and can be done in any quantity now a days. There is polyurethane casting for prototyping and small runs of 10-100pcs.
    Next step would be injection moulding with an aluminium tool, they are a lot cheaper to manufacture than the high-end steel ones and yield y few hundred to maybe 1k pieces and if you are going really big you can scale up to steel tools and produce several 10k-100k per tool ( I pulled those numbers out of my nose but this is the range I remember).
    The issue is that I can't design the mechanical parts so that they are only feasibly manufacturable with injection moulding.
    This is because I have a second target audience that I personally find most exiting and is what drives me personally. It's the hardware hacker crowd, the educational crowd, the mid-size company that wants 10 super specialized tablets that integrates their own weird oddball hardware.
    Those people want to modify the hardware, they want to experiment, they want to make their own spin-off.
    For this audience I need to think about hack-ability. It doesn't mean they don't want a somewhat good looking tablet, but extendability is key here.
    This is one reason why I design the electronics in a very modular way, no peripheral is fixed, everything is changeable. Don't need HDMI output? Then don't get the HDMI PCB. Need it 2 years later? Just buy it for a small amount and add it to your tablet, no need to buy a whole new thing. This not only allows upgrading to some degree, it also allows for great repairability which is something pretty much everyone likes.
    Now there is a catch here, how do I add an HDMI port to a case that doesn't have an opening for it?
    This why I decided to design the case in the following way. There will be a display assembly that consists of LCD, Touchscreen (the two will not be bonded for repairability) and a plastic 'spacer' that creates a frame around the LCD. This assembly is then acting as a flat surface where the aluminium plate will be attached to.
    This plate will have a sort of pegboard pattern of 2.5mm threaded holes where the electronics can be attached to, this allows for free placement of all peripherals and the motherboard. This plate can be easily manufactured in lots of different processes, its thin enough to be done in a sheet metal process, using water-jets or lasers, or more expensively, on a milling machine.
    The tapping will be a bit more expensive than just having threads in a limited amount of places for a fixed set of peripherals but this...
  • LCD and Touchscreen combo
    Prof. Fartsparkle07/07/2019 at 20:46 0 comments
    I got a nice 8.9" eDP LCD and a fitting touchscreen with a glass cover in typical tablet style, they only got white in stock, I would prefer black for future tests but it works well for first tests. Touchscreen was working perfectly in Ubuntu out of the box.
  • Revision 2 ordered
    Prof. Fartsparkle07/07/2019 at 20:34 0 comments
    It's been quite a while since the last update. Some private events kept me busy for a few weeks and I had somewhat of a slump, the second prototype was all about defining sensible pinouts for all the FFC's, finding out what connectors to use, what pin counts, what problems could arise in different applications than mine with the pinout I'm choosing and lots of other little decisions.
    It's important work but can feel a bit like a drag because you essentially just redo what you already did in a different way.
    I've worked through the slump and churned out a new motherboard and over the weekend I made 7 little peripheral breakouts.
    This will be the first proper proof of concept. The part I'm most anxious about is the eDP to LCD part, I've never talked to eDP LCD directly before, so lots of stuff I could have missed.
    Now that I'm waiting probably about 2 weeks for all those boards to arrive I will focus on milling a prototype aluminium frame to attach these PCBs to. I also got a nice LCD and touchscreen from a vendor, more about that in the next post.
  • Found all the bugs, working on next design
    Prof. Fartsparkle06/12/2019 at 21:17 1 comment
    So turns out I simply forgot to connect the AUX_GND pin for the DisplayPort connector, a quick bodge wire and DisplayPort was working as well :)
    Ethernet is only 100Mbits because I mixed up the connector pinout. Molex had two versions for the part that I used and for some reason the bi-color MagJack has a different pinout for the diff. pairs rendering 2 pairs useless which makes me end up with just a 100Mbit connection.
    I have ordered the correct part for the pinout and will see if it works ok after reworking it.
    I'm currently in the process of designing the next prototype which will be the actual first prototype meant for the tablet instead of a SBC like before.
    It will be as compact as possible and breakout everything over FFC like I planed. This also means I have to spec the electrical standards for each peripheral. This will probably not be final but its important to keep future solutions in mind here already. After all its supposed to be a universal standard for portables, not just for my initial tablet here.
    I expect this to take another 2-3 weeks as I wont have too much time due to private life stuff.
    But I want to see it assembled in mid July and maybe do a second revision before the judging deadline in late August.
  • It's alive!
    Prof. Fartsparkle05/28/2019 at 22:25 2 comments
    So the PCB came yesterday and it looks super pretty! It's a 4 layer board with impedance control.
    Also thanks to JLCPCB for sponsoring the board.
    The best part is, after soldering it together, it was actually working! Well everything except for DisplayPort.
    A friend suggested that I used the pin layout for a DP Sink instead of a DP Source. Who knew that existed! So you have the layout reversed depending on whether you transmit or receive the signal.
    I tried reversing the connector but that unfortunately did not change anything. Will have to further investigate why.
  • Mechanical Design
    Prof. Fartsparkle05/25/2019 at 22:03 1 comment
    I haven't talked too much about the mechanical side yet, which I want to change now. I did some sketches in Fusion to illustrate what I want to do here.
    I want to make the mechanical design akin to how a PC case works. So it is a generic mounting point and shell for the hardware, you are able to change hardware without also buying a completely new case.
    This is a bit tricky when you have so little room like in a tablet but it is doable to a degree. I want you to at least be able to swap out peripheral connections or add/remove them. Maybe you want a 6.3mm Audio Jack because you are an audiophile or you want a GPIO header on the side for hacking on the go.
    I want to keep the amount of parts needed to a minimum. This keeps costs down especially when manufacturing the project on a larger scale. If only have to buy tooling to 1-2 plastic pieces that saves a ton of money for smaller production runs.
    The frame is made out of 3 major pieces at the moment and is hold together by 4 screws (that might change as it is likely that is not stiff enough on the long side of the tablet).
    Here an exploded view of the current design. Bare in mind that this is still largely conceptual and it misses some details like studs that will be needed for stability of the back f.e.
    The back is hollow and offers room in addition to space the aluminium mounting plate already creates.
    This gives me 7mm space for hardware at the moment. I might have to increase this to 9-10mm by increasing the tablet thickness but I would like to avoid it. At the moment the tablet would have a thickness of 14mm which is about 2012 era tablet thickness. Which is still absoultely ok for me. This makes the product more hacker friendly (and repairable!). If you are looking for a 7mm iPad you will probably just get an iPad...
    The idea with the mounting plate is that it defines a mounting standard similar to that of expansion slots in a PC case.
    It has M2.5 threaded holes which are spaced 5mm apart giving you a nice even grid of 5mm steps.
    There you can attach small PCBs for the peripherals that you wish to use (as well as the mainboard through another small mounting plate that takes heat away from the SoC to the large mounting plate).
    The mainboard will offer several FFC connectors that break out all relevant peripherals. So each peripheral will connect to the outgoing connector through a flat flex cable.
    This makes the mainboard itself very compact and you have the total freedom of where you want to have which functionality!
    The only thing you would have to re-do is the plastic backplate. There are two options here. Have this be constructed out of one large back part and several smaller spacer parts that you could put between peripheral PCBs to close up the sides.
    Or you have a single piece and you will have to print or mill yourself a new one.
    From a product perspective I might offer both options. The latter looks much nicer, the former is more hacker friendly but actually very cheap to produce. It would actually make it possible to laser cut the whole assembly.
    Here are some renderings. I'm still missing some dummy PCBs, I will add those in later to make it clear how the whole modular peripheral thing is supposed to work.
View all 16 project logs
Asher Gomez wrote 08/09/2019 at 23:21 point
Since I like naming things with acronyms I would have ended up naming this "MOSH-T" now that I think about it.
bylaws wrote 07/12/2019 at 15:45 point
It could be an idea if you are using usb c to use dp over usb c. l4t has native support for the cypress CCGx Type-C controller but not sure if that can be easily brought
Prof. Fartsparkle wrote 07/12/2019 at 18:44 point
That sound interesting. Finding the right solution for PD is a challenge so far.
Do you have link for those kernel modules?
Asher Gomez wrote 07/10/2019 at 20:44 point
Another question, will this be sold on Tindie or any other platform?
Prof. Fartsparkle wrote 07/11/2019 at 22:50 point
No plans at this point, its very early in the development process. The first thing will probably be kits for self assembly but no ETA for that, I'm estimating that it will take a good year to get to that stage as I'm developing this in my spare time.
Asher Gomez wrote 07/10/2019 at 19:24 point
This is made for running full-fledged 32-bit Linux right?
colton.baldridge wrote 07/10/2019 at 21:07 point
The Jetson Nano has a 64bit Cortex-A57 processor, so it should run 64bit linux without issue.
bsdwatch wrote 06/20/2019 at 05:48 point
Nano docs have been released, I could collaborate with you, as I have full desktop Nano images built with Yocto, and well there is a Armbiian build and well Nvidias own Ubuntu.
jimmyplaysdrums wrote 06/18/2019 at 20:53 point
Can't wait to see how this evolves!
Asher Gomez wrote 06/18/2019 at 18:29 point
Coming along real well! Can't wait to get my hands on one!
Peter S. wrote 06/15/2019 at 07:50 point
Cool, gimme !
Mhowser wrote 06/14/2019 at 23:44 point
I hope this doesn't die off like the Neo900 did...
devxxl wrote 06/13/2019 at 12:40 point
I've built one with Jetson TX2 a year ago, it works, IPS 1920x1080 screen, many usb ports, HDMI input for image recognition, classification and all sort of other stuff... tested up to 44C under direct sunlight at Abu Dhabi, CPU complex reaches up to 85C, has Li-Ion for stability. https://tarsens.files.wordpress.com/2018/12/img_0270ssss.jpg good luck with your experiment.
Kevin Kreiser wrote 06/13/2019 at 02:24 point
how were you thinking of handling the heatsink for the SOM or just cooling in general? it seems like the "OEM" heatsinks are all way too big to squeeze into your case (just eyeballing it). will active cooling be needed in such a tight environment? keep up the good work!
Prof. Fartsparkle wrote 06/20/2019 at 21:47 point
I hope to avoid it, I will post an update soon that goes into details regarding thermal design but essentially I want to reverse mount it to the large aluminium frame outlined in the mechanical design project log.
bylaws wrote 06/08/2019 at 12:58 point
You might want to consider using a bq24192 charging ic, it is well supported by the l4t kernel and provides an otg 5v vbus supply if needed. This can be paired with some USB PD chip if you want fast charging.
Prof. Fartsparkle wrote 06/20/2019 at 21:45 point
Thanks for the tip, I was looking through TI portfolio already but have a hard time deciding on a charger, they have a ton of options..
kwapiszon wrote 06/07/2019 at 11:12 point
Pine64 will be gread, but fpga will be greatest.
Small fpga are extremely nice glue for joining arm procesor and for example second arm procesor or x86 procesor or other fpga.
Power ware important. FPGA get small power and can emulate console/dos/zx spectrum etc.
Juan Rial wrote 06/07/2019 at 08:25 point
The i.MX 8M is what Librem is using for their Librem 5 Linux phone. I know you already went with another SoM, but perhaps their git repos are worth checking out, should the Jetson Nano not work out.
Anyway, once that phone is finally launched, a tablet becomes low hanging fruit for them. I guess we'll see a Librem tablet pretty soon as well. That means you can probably leverage their software efforts to improve the user experience of the DLT One. :)
Prof. Fartsparkle wrote 06/07/2019 at 10:51 point
Is their hardware open? I couldn't find anything last time I looked.
The i.MX8M is not dead for this projects, its just something I will look into at a different point when I got a working version going with the Jetson.
The Jetson Nano got a far better performance though, its one reason why I went with this first. The power users will be a lot happier with this than the i.MX8M. The i.MX8M is much more battery friendly though and a bit more power efficient, which is reeeally important for the small phone formfactor. I have a lot more thermal lee way with my 7-10" form factor.
Juan Rial wrote 06/07/2019 at 11:12 point
From their FAQ at https://puri.sm/faq/:
- Will this be an “open hardware” design?
=> Our intention is to have everything freed down to the schematic level, but have not cleared all design, patents, legal, and contractual details. We will continue to advance toward this goal as it aligns with our long-term beliefs.
So basically, that's the intention, but I don't think they have released anything yet. Then again, the thing isn't released yet either, they're still tweaking the hardware.
david.boosalis wrote 06/07/2019 at 07:25 point
Great project. I could see it filling a rather large niche for a   embedded  small touch screen  device. If it could support the Yocto build system I think it would be golden
Prof. Fartsparkle wrote 06/07/2019 at 10:52 point
It is supported by third party efforts: https://github.com/madisongh/meta-tegra
BTPankow wrote 06/07/2019 at 02:19 point
Cool project! Where did you get the Jetson Nano hardware documentation? I’ve been looking all over for it, it seems like a neat piece of tech.
Prof. Fartsparkle wrote 06/07/2019 at 10:53 point
I had to sign an NDA. They will release that in a few weeks though, the current dev kit and module will change accoding to a forum post by Nvidia so its probably best that the current deprecated documentation isnt public.
JavaScriptDude wrote 06/07/2019 at 01:53 point
Is it possible to add a kill switch so if you want to go totally gene hackman (ala the conversation) by being able to disable the camera's, microphones and maybe another to kill switch for bluetooth, wifi (nfc).
Nicolò wrote 06/06/2019 at 19:31 point
Glad to see that I'm not the only one that create footprint upside-down Doh!
Prof. Fartsparkle wrote 06/07/2019 at 10:55 point
It turned out it wasn't the footprint, I just forgot to connect the AUX gnd in my schematic. DP is actually working now, will post an update soon :)
Renaud Lepage wrote 06/06/2019 at 18:49 point
A tablet with a Jetson Nano chip?
Gimme.
chris wrote 05/30/2019 at 08:44 point
This is way cool. I'm been so desirous for a full blown Linux Tablet, something in the hardware realm of the Microsoft Surface Pro. My needs are a bit more high end (lots of RAM ~ 32GB, and at least 1TB disk) as I'm running lots of VM's. Need something that can replace my laptop and iPad\Android Tablets...one device to do it all that runs Linux Proper (not WinBLOWS).
Best of luck with this...
