It's alive!
A project log for DLT one - A Damn Linux Tablet!
Modular Open Source Hardware Tablet that is easy to hack and can run a standard Desktop Linux Distribution (or Android)
timonskutimonsku 05/28/2019 at 22:252 Comments
So the PCB came yesterday and it looks super pretty! It's a 4 layer board with impedance control.
Also thanks to JLCPCB for sponsoring the board.
The best part is, after soldering it together, it was actually working! Well everything except for DisplayPort.
A friend suggested that I used the pin layout for a DP Sink instead of a DP Source. Who knew that existed! So you have the layout reversed depending on whether you transmit or receive the signal.
I tried reversing the connector but that unfortunately did not change anything. Will have to further investigate why.
deʃhipu wrote 06/10/2019 at 16:15 point
that simply doesn't happen
Richard Hogben wrote 06/10/2019 at 15:18 point
Nice looking board :)
