NodeMCU Sexy Curtains
Day-Night Curtains plus Voice
The room employing this particular device is un-ish-viewable during the day light tho highly visible at night with interior lights, alight.  Due to these parameters, the curtains automatically (photoresistor) open-close relative. Amended is a wifi (lower-case) channel to permit a voice activated command (url submit) to open-close the curtains, shd the moment arise, mmm-hmm.
Notation(s)
1. Timing is every thing .. preferring servos as opposed to steppers, this code requires a precise timing-per-rotation for the width of the curtain draw.
2. Patience .. just bcz it runs at 16mhz doesn't mean you shd. Averaging sensor reads .. delays .. give 'er a rest other wise the curtains will be flappin' back and forth like a chicken raised by geese tryin' to head south.
Archive
http://vijemiller.com/index.php?entry=entry190524-042126
gear_post_2.skp
Pulley(s)
SSEYO Koan Play File - 475.05 kB - 05/13/2019 at 22:20
Download
mico_servo_holder_mount_1.skp
Micro Servo 9G Wall Mount Holder-Clamp (Sketchup)
SSEYO Koan Play File - 1.58 MB - 05/09/2019 at 17:15
Download
  • 1 × NodeMCU ESP8266 12E
  • 2 × Servo MG995 (mod' to 360)
  • 1 × Photoresistor
  • 2 × String
  • You'se Gots Changes
    Vije Miller05/14/2019 at 03:40 0 comments
  • Codeen Addiction
    Vije Miller05/12/2019 at 03:00 0 comments
    // NodeMCU Sexy Curtains
    // Vije Miller
    #include <ESP8266WiFi.h>
    #include <Servo.h>
    // Wifi Data (Static)
    IPAddress ip(192, 168, 1, 47);
    IPAddress gateway(192, 168, 1, 1);
    IPAddress subnet(255, 255, 255, 0);
    const char* ssid = "ssid";
    const char* pass = "password";
    WiFiServer server(80);
    Servo left;
    Servo right;
    // Stop
    int zero = 90;
    int ols = 85;
    int ors = 95;
    int cls = 95;
    int crs = 85;
    // Servo Position (Time)
    // 1 = 1 Second = Full Close
    // 10 = Full Open
    int pos = 0;
    // Half Rotation -> Specific
    int slow = 910;
    int full = 10;
    int sensor = 0;
    void setup() {
      Serial.begin(115200);
      left.attach(D5);
      right.attach(D6);
      left.write(zero);
      right.write(zero);
      // Connect
      Serial.print("SSID: ");
      Serial.println(ssid);
      WiFi.config(ip, gateway, subnet);
      WiFi.begin(ssid, pass);
      while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
      Serial.println("Connected");
      server.begin();
      Serial.print("http://");
      Serial.print(WiFi.localIP());
      Serial.println("/");
      delay(5000);
    void loop() {
      // Sensin'
      sensor = analogRead(A0);
      // Convert to simplier times
      sensor = map(sensor, 0, 1023, 0, full);
      // Gotta' see it to believe it
      Serial.print(sensor);
      Serial.print("  ");
      Serial.println(pos);
      // Listenin'?
      WiFiClient client = server.available();
      if (client) {
        if (client.available()) {
          String query = client.readStringUntil('\r');
          if (query.indexOf("/o") != -1)  {
            open_fast();
            Serial.print(pos);
            Serial.print(" ");
            Serial.println("open fast");
            delay(200000);
          } else if (query.indexOf("/c") != -1)  {
            close_fast();
            Serial.print(pos);
            Serial.print(" ");
            Serial.println("close fast");
            // Set to a generous (2) minutes for sex
            delay(200000);
        client.flush();
      // Now whadda'ya do?
      if (sensor > pos) {
        open_slow();
      } else if (sensor < pos) {
        close_slow();
      } else {
        hold();
      delay(100);
    void open_slow() {
      if (pos < full) {
        left.write(ols);
        right.write(ors);
        delay(slow);
        pos++;
      hold();
    void close_slow() {
      if (pos > 0) {
        left.write(cls);
        right.write(crs);
        delay(slow);
        pos--;
      hold();
    void open_fast() {
      if (pos < full) {
        left.write(ols);
        right.write(ors);
        pos = pos * 1000;
        delay(pos);
        pos = full;
      hold();
    void close_fast() {
      if (pos > 0) {
        left.write(cls);
        right.write(crs);
        pos = pos * 1000;
        delay(pos);
        pos = 0;
      hold();
    // Don't ya' move
    void hold() {
      left.write(zero);
      right.write(zero);
      delay(5000);
  • You are why cavemen printed in PLA
    Vije Miller05/09/2019 at 23:49 0 comments
  • 360 Kick Flip Micro Servo 9G
    Vije Miller04/12/2019 at 00:23 0 comments
View all 4 project logs
Daren Schwenke wrote 05/12/2019 at 03:23 point
I likey.  Build one that fits inside the non-springy end of a pull-down shade, and you have an actual marketable product.
Vije Miller wrote 05/12/2019 at 23:09 point
They already 'make-r' such a thing which is also why I am not making a big deal about this one. More or less this was an experiment on timing servos, reading sensors and listening for wifi on the NodeMCU .. for a friend.
