Moving in project
A project log for Soviet Nixie Clock
Nixie clock with Android support, Web interface support, FM radio, clock/date, sensors, relays, web stream radio stations, bt/wifi control
loszelosloszelos 05/28/2019 at 17:240 Comments
Hey all !! I would like to exuse me, because I didn't write a log from build too long.
I was in hospital on surgery, my healt wasn't so good to make everything new. I had broken my 3D printer and just now I think, that I repaired finally it and I'm able to make a new parts.  I have almost done my new CNC machine for milling PCB, because I want to make a great proffesional look of them.
I have also almost more than 50% of code done and just now is situation, that I have to done PCBs due to programing with HW which is necessary for continue in programming.
When I will have done PCB milling machine and I will be sure that printer is correct, I will make the first prototype of PCBs and if everything will be allright I will upload files, schematics, gerber.
Soo, thanks for patience..
