Final video of the Soviet Nixie Clock
05/04/2020 at 20:38 • 0 comments -
Few next days up!
06/21/2019 at 05:30 • 0 commentsI'm toooooo sorry, for this very late log. I was on surgery, therefore I was long off. Just now, I had to prepare for exams at my school. I was too busy, but however, I wanted to write this short topic. Just now, I'm almost done with my CNC mill for PCB and small components machine, here this are potos and link for do it :-)
To All: Please be patiently. Just now we will start holidays = more more time for developing 8-)
The CNC is printed from : https://www.thingiverse.com/thing:1719334
I'm decided little bit change some things, for better stability and use not nema17 but nema23 for Y axis. The machine is very heavy and it's problem, to run up with small torque of nema17.
See ya in the next topic! Roman
Moving in project
05/28/2019 at 17:24 • 0 commentsHey all !! I would like to exuse me, because I didn't write a log from build too long.
I was in hospital on surgery, my healt wasn't so good to make everything new. I had broken my 3D printer and just now I think, that I repaired finally it and I'm able to make a new parts. I have almost done my new CNC machine for milling PCB, because I want to make a great proffesional look of them.
I have also almost more than 50% of code done and just now is situation, that I have to done PCBs due to programing with HW which is necessary for continue in programming.
When I will have done PCB milling machine and I will be sure that printer is correct, I will make the first prototype of PCBs and if everything will be allright I will upload files, schematics, gerber.
Soo, thanks for patience..
!THE FIRST TASTE OF THE PROJECT!
04/21/2019 at 12:52 • 0 commentsHey !! I'm soooooo glad and excited, that I can upload first pictures of boards! I'm still working on them, and lot of job is done. Just now, it's under finishing and correcting and testing. When I will be done, I will upload first files for download. Sooo please be patient.
!!!THE HACKADAY DEVELOPER TOURNAMENT HAS STARTED!!!
04/21/2019 at 12:39 • 0 comments![]()
loszelos
