utilize the ALSA lib
A project log for DJmixer
This is a project of building DJmixer using raspberry pi with four ultrasonic sensors to playback and loop the music, and change the volumn
ten000hoursTen000hours 04/14/2019 at 22:160 Comments
To perform the music in raspberry pi, we apply the ALSA lib in linux to drive the raspi to play and control the music. Details are as following .
int main() {
  long loops;
  int rc;
  int size;
  snd_pcm_t *handle;
  snd_pcm_hw_params_t *params;
  unsigned int val;
  int dir;
  snd_pcm_uframes_t frames;
  char *buffer;
  /* Open PCM device for playback. */
  rc = snd_pcm_open(&handle, "default",
                    SND_PCM_STREAM_PLAYBACK, 0);
  if (rc < 0) {
    fprintf(stderr,
            "unable to open pcm device: %s\n",
            snd_strerror(rc));
    exit(1);
  /* Allocate a hardware parameters object. */
  snd_pcm_hw_params_alloca(¶ms);
  /* Fill it in with default values. */
  snd_pcm_hw_params_any(handle, params);
  /* Set the desired hardware parameters. */
  /* Interleaved mode */
  snd_pcm_hw_params_set_access(handle, params,
                      SND_PCM_ACCESS_RW_INTERLEAVED);
  /* Signed 16-bit little-endian format */
  snd_pcm_hw_params_set_format(handle, params,
                              SND_PCM_FORMAT_S16_LE);
  /* Two channels (stereo) */
  snd_pcm_hw_params_set_channels(handle, params, 2);
  /* 44100 bits/second sampling rate (CD quality) */
  val = 44100;
  snd_pcm_hw_params_set_rate_near(handle, params,
                                  &val, &dir);
  /* Set period size to 32 frames. */
  frames = 32;
  snd_pcm_hw_params_set_period_size_near(handle,
                              params, &frames, &dir);
  /* Write the parameters to the driver */
  rc = snd_pcm_hw_params(handle, params);
  if (rc < 0) {
    fprintf(stderr,
            "unable to set hw parameters: %s\n",
            snd_strerror(rc));
    exit(1);
  /* Use a buffer large enough to hold one period */
  snd_pcm_hw_params_get_period_size(params, &frames,
                                    &dir);
  size = frames * 4; /* 2 bytes/sample, 2 channels */
  buffer = (char *) malloc(size);
  /* We want to loop for 5 seconds */
  snd_pcm_hw_params_get_period_time(params,
                                    &val, &dir);
  /* 5 seconds in microseconds divided by
   * period time */
  loops = 5000000 / val;
  while (1) {
  //  loops--;
  //  printf("%ld\n", loops);
    rc = read(0, buffer, size);
       if (rc == 0) {
      fprintf(stderr, "end of file on input\n");
      break;
    } else if (rc != size) {
      fprintf(stderr,
              "short read: read %d bytes\n", rc);
    rc = snd_pcm_writei(handle, buffer, frames);
    if (rc == -EPIPE) {
      /* EPIPE means underrun */
      fprintf(stderr, "underrun occurred\n");
      snd_pcm_prepare(handle);
    } else if (rc < 0) {
      fprintf(stderr,
              "error from writei: %s\n",
              snd_strerror(rc));
    }  else if (rc != (int)frames) {
      fprintf(stderr,
              "short write, write %d frames\n", rc);
  snd_pcm_drain(handle);
  snd_pcm_close(handle);
  free(buffer);
  return 0;
