it's all about Connection
05/01/2019 at 20:21 • 0 commentsThe backbone of the entire system will be the ability to connect the various node, in the need of identify the best way to do so, i have selected five alternatives:
> KNX
> CAN
> DALI
> WIFI/RF
> Developing a proprietary protocol based on DALI and CAN(+) Pro
(-) ConsKNX (TP)
- requires complex power supply
- little choice of transceiver ICs (more expensive)
+ only 2 wires for bus and power supply
+ multimaster
+ line/bus, tree and star topology are allowedCAN
- requires 4 wires, two for power and two for the bus
- only line/bus topology
- requires termination resistance
+ multimaster
+ cheaper transceiversDALI
- Manchester encoding
- master/slave (dali 1)
+ simple power supply
+ the interface is realizable with passive components
+ line/bus and star topology are allowedWIFI/RF
- requires power supply (mains)
- not good if is inserted inside the wall
+ simple to implement + tree, star and mesh topology are allowedDeveloping a proprietary protocol based on DALI and CAN
(HW interface based on DALI protocol based on CAN)
- everything needs to be developed (HW & SW)
+ only 2 wires for bus and power supply (DALI)
+ simple power supply (DALI)
+ the interface is realizable with passive components (DALI)
+ line/bus and star topology are allowed (DALI)
+ mltimaster (CAN) -
First log, first block ...
04/10/2019 at 22:11 • 0 commentsThe first subsystem I'm working on is the light control.
It is possible to have two cases:
To ensure that it is possible to drive the light from any switch the node must behave as a 4 way switch.
1) more than one control per light point
2) a single control for light pointThe first case is the simplest, it is sufficient to connect the node in series to the switches [1].
The second case is slightly more tricky, it is necessary to replace the single switch with a 2-way switch and put it in series with the node [2a], or with a push-button connected directly to the node [2b].
The "SWITCH NODE" must have three functions:
- switch ON/OFF the load
- sense if the load is ON or OFF
- communicate to receive commands and send the status of the load
