Opcode handling
A project log for Kobold - retro TTL computer
A 16 bit computer with 20 address bits and video display, from just a few TTL and memory chips. Instructions resemble 68000 / PDP-11.
roelhroelh 04/15/2019 at 17:173 Comments
The Kobold is advertised to handle 16 bit instructions, but everything is 8 bit. Even the microcode is only 8 bit wide. How does it work ?
[ What you need to know for the examples: The program counter is in register R7 (as on the PDP11), and is copied into address register PC when needed. The lowest bit of the PC is always 0.]
EXAMPLE: 16-bit ADD
As example, take an instruction that adds (X+6) to register R4:
 add (X+6),R4
The instruction is split into two parts, that operate almost independent of each other:
The first byte of the instruction is fetched from (PC) into the micro-program counter. From here, the micro-instructions determine the operation:
This instruction byte tells to add R4 (16 bits) to the accumulator and store the result back to R4:
The next section of the microcode will increment the PC and start the next instruction:
EXAMPLE: 8 bit immediate load
There are also instructions that have a single opcode byte, followed by an 8-bit immediate operand or z-page location. Branch instructions are  an example of this.
As example, load register R3 with value 0x80:
mov #0x80,R3
Finally, the pc is incremented and the next instruction is fetched, as in the previous example.
Yann Guidon / YGDES wrote 04/16/2019 at 03:13 point
It's funny how we were used to CISC 40 years ago and now I cringe at the evocation of this idea :-D
roelh wrote 04/16/2019 at 11:30 point
I'm sorry Yann, the minimum parts requirement drove Kobold in the arms of CISC....
Yann Guidon / YGDES wrote 04/16/2019 at 16:20 point
I notice that the CISC way can require more gates than RISC because you need some scheduling here, buffers there, some fix for a corner case...
That's why I prefer to focus on the core datapath (speed/efficiency/simplicity), then I build decoders out/around :-)
